Need 6V 10A Power Supply
Discussion in 'The Projects Forum' started by bencyp, Jun 16, 2010.
  1. bencyp
    Jun 16, 2010
    Can anyone provide me the circuit of a 6V 10A SMPS along with transformer design details?
    Or give me a high current regulator which will regulate a 12V 15A to 6V 10A without much components. I mean I do not have space for having heatsinks.
    Regards,
    Bency
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    6V * 10A = 60 Watts power out.
    If you get a design that's 85% efficient (which isn't bad at all) then you'll have 66 Watts input. You'll have to get rid of the 6 Watts of heat somehow, or your project will have a melt-down.
    If you "don't have room for heat sinks", you better re-think your entire design.
  3. kingdano
    Member
    Apr 14, 2010
    377
    19
    have you checked digikey?
    jameco?
    anything?
  4. kingdano
    Member
    Apr 14, 2010
    377
    19
  5. Solcar
    Member
    Jun 8, 2007
    21
    I would boost the output of the National Semiconductor Simple Switcher IC with an external tranasistor (bipolar or MOSFET) to step your 12v down to 6V.
  6. Solcar
    Member
    Jun 8, 2007
    21
    Or try something like in a an LTspice simulation (you will have to modify as needed).
  7. Norfindel
    Mar 6, 2008
    235
    9
    Can you give us more details on the project? Maybe there is a better way to do it, like changing the transformer for one with a center-tap.
    I'm confused. Why 6V * 10A is = to 138.6 watts? Wouldn't that be 60W?
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Thank you for correcting my stupidity. All I can offer as an excuse for my original very incorrect reply is that the coffee had not taken effect yet. :rolleyes:
  9. retched
    Dec 5, 2009
    5,201
    313
    WOAH, I gotta get me some of that coffee. Maybe that will help my calculations... which are usually grossly missed. ;)
  10. Norfindel
    Mar 6, 2008
    235
    9
    Oh, well, let he who is free of mistakes and smoked components throw the first rock :D
