Need 12v from 9volt
Discussion in 'General Electronics Chat' started by blanius, Jan 4, 2011.
  1. blanius
    Jan 4, 2011
    I'm not an electronics person but I need to power up a device that requires 12v using 9volt battery or even two 9v batteries to start with 18v. I need to put together something very small and was looking at lm317
    12v-----[lm317]---|
    | | 1.6 2w Resistor
    | |_____|
    Does that sound about right?
  2. Kermit2
    Feb 5, 2010
    3,856
    968
    Do you HAVE to use 9 volt batteries?
    They have extremely poor current output. Draw more than 20-30 mA and the voltage will fall to 6 volts or lower.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If the 9 volt batteries are the only way, then a 7812 regulator at least saves parts. It will only need a 1 uF capacitor on the input and a .1 on the output.
  4. edgetrigger
    Member
    Dec 19, 2010
    133
    19
    if you want to use two 9 volts then connect it in series and take the output through 7812.
    Or connect two 1.5 volts cell in series with a 9v to get 12
  5. edgetrigger
    Member
    Dec 19, 2010
    133
    19
