Nedded help to run my Raspberry Pi from Battery
Sharfuddin Shawon
Joined Nov 5, 2013
6
I want to run my Raspberry Pi from batteries. I am wishing to use a 9v battery.
But due to lack of Electrical Knowledge I am not sure how to get 5v regulated voltage with 2amp current...
Sorry for Bad English.
Thanks in advance,
Shawon.
Ramussons
Joined May 3, 2013
1,414
9 Volt batteries, normally available are type PP9, and will not be able to give 2 amps.
I would suggest using a 6 or 12 V rechargeable battery with a 5 Volt SMPS.
Ramesh
Sharfuddin Shawon
Joined Nov 5, 2013
6
Ok, what if i want to use a 6v, 4.5Ah battery?
I meant, which IC/regulator should i use and what kinds of schemetic should i follow?
And what does 'SMPS' mean?
Sharfuddin Shawon
Joined Nov 5, 2013
6
Actually i would not need exact 2A always; but somtimes I may need. Thats why i am planning to build one with atleast 2amp output.
And i think, 2A will not harm my RPi, if i use so instead of 750mAh? ;)
BTW, Thanks.
Ramussons
Joined May 3, 2013
1,414
Switched Mode Power Supply.
Normally, the Maximum Rate for Charging / Discharging is at 1/10 of the AH value - for a 4.5 AH battery it would be 450 mA.
Ramesh
