nedd help simplifing circuit diagram
Discussion in 'The Projects Forum' started by sumit231996, Oct 14, 2014.
  1. sumit231996
    Oct 14, 2014
    14
    I am making this project which I found here
    http://m.instructables.com/id/Potable-9v-dark-activated-light/
    the problem is I am much new to this and need help in understanding the two circuits in they project. I know the components used very well. All I need is a simplified diagram of circuit with all connection joined. The broken connection are confusing me. If any one could redraw the two into one that would be a lot of help.
    thanking in anticipation.
  2. adam555
    Aug 17, 2013
    858
    39
    All the top connections go to the positive of the 9v battery, and all the bottom connections (with the ground symbol) to the negative -you can simply draw a horizontal line connecting all of them-. The LEDs connects in the same orientation -top with top and bottom with bottom-.
  3. sumit231996
    Oct 14, 2014
    14
    thanks a lot.
