Neat Ohms law sticker
Discussion in 'Off-Topic' started by maxpower097, Nov 11, 2011.
  1. maxpower097
    Feb 20, 2009
    795
    388
  2. jimkeith
    Oct 26, 2011
    539
    99
    Get rich quick!
    How about a screen saver?
  3. djsfantasi
    Apr 11, 2010
    2,904
    878
    States right on the sticker that is is copryrighted 2007 by TxxP.com
  4. t06afre
    May 11, 2009
    5,939
    1,222
    I am quite sure I first saw that wheel long time before 2007. So if you strip of the graphic it should be OK.
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  6. t06afre
    May 11, 2009
    5,939
    1,222
  7. maxpower097
    Feb 20, 2009
    795
    388
    The color, shape, and logo are copyrighted, the laws are not. You could design your own chart. Hell I'll whip you guys up a desktop.
  8. maxpower097
    Feb 20, 2009
    795
    388
    Heres some basic ones I whipped up for yah. If you guys want to make a big forumla chart or what have you. I'd be happy to do the graphics and design work.
  9. maxpower097
    Feb 20, 2009
    795
    388
    The key is these are stickers to buy to put around your workstation. Sure images are easy to find and get. But a stickers a little but more then a jpg.
  10. Georacer
    Nov 25, 2009
    5,151
    1,266
    Not really. Sticker A4 paper is quite common. You can print on it and cut it around.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    I keep a roll of carpet tape around myself. It is double sided, and extremely tough. You can attach it anything, and make a label out of it.
  12. JoeJester
    Apr 26, 2005
    3,400
    1,218
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    Scotch 77 spray adhesive. Makes anything a sticker, a little permanent though, so if you print out that chart on an ink jet, be sure to spray it with Fixative (from an art store, best choice), or clear paint ( second choice, may cause colors to bleed if put on too thick).
  14. someonesdad
    Jul 7, 2009
    1,585
    141
    No need for a sticker. Just learn that the definition of resistance is voltage divided by current. Use algebra to get the other forms.
    Basic physics tells us that the change in kinetic energy of a charge q "falling" through a potential V is qV. Thus,
    \Delta (Energy) = i \Delta t V
    Divide by \Delta t and take the limit to get P = Vi. Derive other forms via algebra.
    Good -- just saved a tree. Oh, OK -- if you need the chart, write it on the wall with a felt pen. :p
  15. #12
    Nov 30, 2010
    16,679
    7,322
    I could swear I saw that labeled as "wire wheel" in the 1970's.
    (Not with the background drawing and the color.)
    I can never remember all the variations of those 2 equasions.
    I think I'll print this and tape it to my workbench.
    Thank you.
  16. maxpower097
    Feb 20, 2009
    795
    388
    Not if you wanna use shiny foil in it and stamp it in cool novelty shapes.
  17. gerty
    Aug 30, 2007
    1,154
    304
    Here's one drawn up by one of my students
