Ne555
Discussion in 'The Projects Forum' started by ramcaress, Mar 1, 2010.
  1. ramcaress
    Mar 1, 2010
    6
    i would like to know if there's a difference between LMC555 and NE555, or something that is CMOS type 555, i built this circuit from EME systems, SMX soil moisture interface but it didn't work, the electronic shop here sells only NE555, pls help, thanks a lot
  2. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Can you google and find the data sheets?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The LMC555 is a CMOS version. It can operate at lower voltages than the NE555 does, and the output is able to reach nearly to both power rails (+V, GND).
    The NE555 needs around 5v to operate, but some circuits won't work with a supply that low, particularly if the timing capacitor is being charged/discharged by the output (pin 3).
    Post the schematic of the circuit, that is the quickest way to get help.
  4. ramcaress
    Mar 1, 2010
    6
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Sorry, it's not going to work on 3.3v with an NE555.
    Are you in the USA? If there is a Radio Shack store nearby, they usually have TLC555 timers in stock. Don't let them sell you anything else, as a standard NE555/LM555/SE555 won't work.
  6. ramcaress
    Mar 1, 2010
    6
    thanks a lot, im goin to look for a cmos type 555, i analyzed the circuit several times but can't look on some errors, its clear now that a standard NE555 won't substitute the cmos type, thanks a lot, more power:):):)
