NE555->optocouler->Mosfet driving problems
Discussion in 'Analog & Mixed-Signal Design' started by patpin, Jul 3, 2016.
  1. patpin
    Sep 15, 2012
    226
    18
    I try to simulate the driving of a transformer (ignition coil) with NE555 and an optocoupler. Anybody could tell me why the mosfet is not stopping to conduct when gate goes high? I see it remains at 26.5 A, which is probably why my secundary tension remains so low...
  2. benta
    Member
    Dec 7, 2015
    101
    24
    Looking at your shcematic, you have drain and source reversed. The body diode in the IRF5305 is conducting.
    Benta.
    patpin and Hypatia's Protege like this.
  3. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,845
    1,311
    Indeed, the IRF5305 is a P-Channel device
    @patpin
    Further to post #2 --- If it was your intention to use an N-channel device -please be advised that a 10K pull-up isn't going to 'cut it' above a few tens of Hz... (to say nothing of 'ground reference' issues, etc...) -- Just reverse D & S in the circuit as shown and all should come well:)
    Nice to see you on the fora again!:cool:
    Best regards
    HP:)
    patpin likes this.
  4. patpin
    Sep 15, 2012
    226
    18
    Thanks Benta. Now it looks OK!
  5. patpin
    Sep 15, 2012
    226
    18
    Hello, nice to see U active!!! I was aboad some time. (BTW the scope is OK)
    I wanted a high side driver so thats why I took the P-chan. About the back EMf potentially destroying the optocoupler and furtther on. Do you think the zener at the primary is OK (as soon as connected)? Any other protection needed?
    Why dont'I see the Voltage peaks (reverse) one normally see's (real life) at the primary?
  6. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    Firstly D3 is drawn 'backwards' (i.e. it would be under forward bias during MOSFET conduction).
    Secondly the MBRS360 is a Schottky rectifier -- Not a Zener (granted - the symbols are similar:)).
    Thirdly Q2 is at far greater jeopardy than U2 -- Still, it happens...:eek:
    FWIW I would use a fast switching diode across the coil (cathode toward the drain of the mosfet) an MBR360 may well be 'up to the job' howbeit I'm dubious of its modest I{f} (3 Amperes) --- A good 'rule of thumb' RE: snubbers holds that peak 'kick' currents approach (but do not exceed) peak forward current through the inductor...
    I apologize that I'm less than useless with simulators!:oops::oops::oops:
    Very best regards
    HP:)
  7. benta
    Member
    Dec 7, 2015
    101
    24
    Question is, how you want to keep the primary voltage under control during turnoff to avoid damage to the MOSFET, and that in turn begs the question what you want your peak secondary voltage (spark) to be.
    The Schottky that is shown on the schematic is the absolutely wrong choice.
    My suggestion would be a bidirectional transorber across the primary, breakdown voltage around 18 V. You may need to help it a bit with a resistive/capacitive snubber in the same location.
    Benta.
  8. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    Assuming low frequency operation (i.e. ≤ 1kHz) I agree -- otherwise a gas discharge device or, better yet, a proper snubber network is the best approach...
    Best regards
    HP
  9. patpin
    Sep 15, 2012
    226
    18
    20KV for secundary is OK; primary in function of that;
    How do U dimension a snubbing network? I read that sometimes there are peaks of up to 400V on the primary (even if battery is 14,4V)
  10. benta
    Member
    Dec 7, 2015
    101
    24
    It would help a h*ll of a lot if you could describe what you are trying to do.
    OK, spark ignition. Automotive?
    What is the turns ratio of your ignition coil? You mention 20 kV secondary voltage, but that does not help us understand primary voltage.
    Your traces suggest a switching frequency of around 100 Hz. But we don't know if it's higher or lower.
    Dimensioning a snubber is not trivial. The parasitic inductances/capacitances of your coil are unknown, as well as the magnetic core properties and general circuit layout. The bidirectional transient absorber (eg, 1.5KE18C) is a start, but only when you have a prototype running, will you see the real spikes.
    I'm a fan of simulators, but when working with magnetics, the end result always looks completely different to what they predict.
    Benta.
    Hypatia's Protege likes this.
  11. patpin
    Sep 15, 2012
    226
    18
  12. patpin
    Sep 15, 2012
    226
    18
    I m not planning to realise a circuit. It is purely theoretical, though with the purpose of beiing able to analyse the scope waveforms from an old Volkswagen with electronic ignition and injection.
    As for the specifs of a typical coil: You find it below.
    As TVS I thought putting one with a Vbr of 50V. Do you think that a TVS can absorb anough energy stored in a coil?
  13. benta
    Member
    Dec 7, 2015
    101
    24
    Now there's something to work with!
    You have a primary/secondary ratio of 1:100
    This means that the the secondary voltage induced to the primary will reach ~450 V (max.) at a 45 kV (max.) spark voltage
    In your place, I'd forget the IRF5305 immediately!!!
    The right power switch would probably be a 1 kV IGBT. In this case you'll need to choose between a low-side switch (=easy drive) or a high-side switch (=optical drive and gate-supply charge pump, alternatively transformer drive) design. High-voltage transistors or IGBTs are generally only available as NPN or N-channel.
    Have Fun.
    Benta.
  14. patpin
    Sep 15, 2012
    226
    18
    When I was 30 years younger I made a electronic ignition with a thyristor and it survived many years.... This was before IGBT's existed. There must be a workaround I presume.
  15. benta
    Member
    Dec 7, 2015
    101
    24
    "When I was 30 years younger I made a electronic ignition with a thyristor and it survived many years.... This was before IGBT's existed. There must be a workaround I presume."
    Well, thyristors usually withstand at least 600 V. And an SCR ignition is a well-known circuit.
    Your IRF5305 will take 55 V.
    I only pointed out that your coil will deliver up to 450 V on the primary, so perhaps a higher voltage device would be right. Your choice...
    Benta.
  16. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    Of course -in theory - almost any device (within reason) may be used as the switch (i.e. without regard to maximum interelctrode EMF specification) use of a 'low voltage' device, however, will require more 'involved' snubber/ 'transformation network' design --- Unless 'exploration' of snubber topology is part of your study, you may save yourself much agro via employment of a device exhibiting a greater maximum V[dss] figure:) -- You may take my word for it that the greater saturated R[ds] exhibited by such devices will be of little consequence in your application:cool:
    Please keep us posted:)
    Best regards
    HP:)
  17. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    +1000 :eek::rolleyes:
  18. patpin
    Sep 15, 2012
    226
    18
    Hallo do U mean Vdss > 1000? Can you suggest a robust HV mosfet resisting the back EMF?
  19. patpin
    Sep 15, 2012
    226
    18
    Thanks, this helps me a bit more. Is there a way to simulate such events as the back EMF in LTSPICE?
  20. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    Sorry for the confusion!:oops: -- "+1000" was merely 'shorthand hyperbole' signifying that I agree with @benta 's statement...
    Please understand that good design will include a snubber (in any event), howbeit the criticality of such considerations is significantly 'eased' via selection of high (Max) Vds switch devices... -- For efficiency and reliability I suggest implementation of a non-dissipative snubber arrangement -- Granting that such elaboration is unnecessary for avocational applications...
    But to answer your question::cool:
    FWIW I use the IXFH20N100P in my X-Ray 'generator' designs (i.e. high power EHT PSUs) with good results -- Don't mind the ≈ 700mV (effective) saturated Rds;)
    In many areas of power conversion I've 'moved on' to IGBT technology - Of course there are pros and cons either way...
    Best regards and good luck
    HP:)
    patpin likes this.
