1. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    hi everyone I am having problem with my circuit. how can I make output up to 8 volts? see my attachment
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
    You'll have to use a higher supply voltage. The timer can only get within 2 diode drops of the supply...
    What problem you're trying to address?
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    The timer shown in the schematic is the CMOS version...
  4. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    i want to use it to my motorcycle for relay of its horn but it needs 8 v to work
  5. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    can you give me a link or a photo please
  6. dl324
    Mar 30, 2015
    3,384
    653
    Which timer are you using? NE555 or a CMOS variant?
    Show the schematic of you're circuit!
    The motorcycle's battery voltage is 8V??
  7. dl324
    Mar 30, 2015
    3,384
    653
    My bad... I didn't pay any attention to the part number in the schematic because the title said NE555...
  8. dl324
    Mar 30, 2015
    3,384
    653
    High output specs for TI LMC555 timer are unexpectedly poor...
    TI datasheet didn't give a schematic.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    You have several problems with this thread. A CMOS 555, which a 7555, simply does not have the drive you want. It simply can not provide enough current.
    The 7555 can go rail to rail, hit both 0V and the power supply voltage.
    I have even used 7555 at low voltages (3V) without a resistor because the drive of this chip is so low.
    Bill's Blog
    Chapter 8 - 555 Timer Circuits
    I am a fan of the 555. I have written a chapter in the AAC textbook showing various circuits this chip can use.
    Kaiser Ed Bayawa likes this.
