I'm wondering how you believe that ANY astable multivibrator can gradually increase from 1Hz to 10Hz in the span of 2 seconds?Hi,
Is there an easy way to use the NE555 to generate pulse that gradually (exponentially rather than linearly preferred) increases from 1 Hz to 10Hz in 1 to 2 second and hold at 10Hz thereafter?
+1Using pin 5 won't work for that wide of a frequency deviation. You might get 30-35%, but our OP wants far more.
Thread starter | Similar threads | Forum | Replies | Date |
YAG 555 help | Digital Design | 6 | ||
Help with using a PIR to trigger a NE555 | General Electronics Chat | 124 | ||
Y | Need help in making our light following robot using NE555 IC's to work on a pcb | Homework Help | 6 | |
Need your help with 7 segment display using 4026 and NE555 | Homework Help | 19 | ||
NE555 timer help please? | Digital Design | 27 |
by Jake Hertz
by Jake Hertz
by Aaron Carman
