Navigation of boat using light house
Discussion in 'General Science' started by guru200773, May 18, 2010.
  1. guru200773
    Apr 26, 2010
    94
    How the boat gets is heading using the light frm the light house.. Pls explain me clearly..
  2. mik3
    Feb 4, 2008
    4,846
    63
    The driver of the boat sees the light and drives towards it. :p
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Maybe not too close, mik3 - the lighthouse marks something that is dangerous to run into.
  4. mik3
    Feb 4, 2008
    4,846
    63
    Ok, I meant use it to find his orientation and not drive the boat exactly towards the light house.
  5. retched
    Dec 5, 2009
    5,201
    313
    The boat navigator has a map that shows the lighthouse locations as well as other landmarks and stars and such. When they see the lighthouse, they align the map with it to get their bearings.
    Some lighthouses are used to mark dangers, like sand bars, shallows, and rocky areas.
    Some lighthouses are used to show the way to port for use in fog and rain and at night.
    When there is more than one lighthouse or buoy. The lightkeeper changes the color of the light.
    Green means pass the light on the left side of the boat
    Red means pass the light on the right.
    If there were huge rocks, they would put a light on the left and right, so you wouldn't run into them in the night or bad weather.
  6. Markd77
    Sep 7, 2009
    2,803
    594
    They flash at different rates and patterns so you can tell which lighthouse it is if you have the right chart (over here anyway).
  7. guru200773
    Apr 26, 2010
    94
    My sir taught me that light house emits a omni directional pulse of light every time the beam is pointing towards due north.. If the speed of rotation of the beam is known a distant observer could record the time interval between seeing the omni directional flash and seeing the beam and hence they calculate the bearing of the light house.. But i asked him that how they calculate the bearing he said i don know.. Thats y i posted a thread here now tell me any one knows how they r calculating the bearing by recording the time interval between seeing the omni directional flash and seeing the beam...? Pls explain me
  8. mik3
    Feb 4, 2008
    4,846
    63
  9. retched
    Dec 5, 2009
    5,201
    313
    Lighthouses no not point light in any particular direction.
    If the lighthouse was in the southern shore of a landmass, the light would flash into the landmass, not being seen to the navigator.
    During Rising and falling seas, lighthouse lights appear to flash when on constantly, but that is optical interference.
    They do flash, but that is in all directions, to distinguish which lighthouse it is.
    http://en.wikipedia.org/wiki/Lighthouse
  10. guru200773
    Apr 26, 2010
    94
    thanks friends
  11. loosewire
    Apr 25, 2008
    1,584
    435
    Most light houses no longer operate,some are endangered.
    Some have been moved for protection. A search of working
    light houses should be made. It hard to tell,the park service
    has taken over a lot them. No longer needed with all the
    electronics. Check It out,If you are positive report working
    location to be sure you have to see light at nite.Good subject
    (guru),you are doing good by posting.
  12. loosewire
    Apr 25, 2008
    1,584
    435
    Saw a story about family in south pacfic on sail boat was rescued
    by setting off rescue beacon.The U.S. received beacon contacted
    nearest country to sent jet ,backed by helicopter.all Five members
    survived.of family.That the way they do It now,you can be safe any
    In the world with a beacon.
  13. loosewire
    Apr 25, 2008
    1,584
    435
    Keep It going Guru,post.
  14. guru200773
    Apr 26, 2010
    94
    ya sure looose wire :)
  15. guru200773
    Apr 26, 2010
    94
    that story is really interesting hmmmm... luck also favors sometimes :D
  16. teno45
    Jun 2, 2010
    I know what your talking about here, and i'll try to give a rough explanation on how it works. I am not saying this is how all lighthouses work, or anything like that. I am just trying to explain how this system the OP is talking about works. It is similar to the concept of VOR (VHF omnidirectional radio range) Navigation systems on aircraft).
    The easiest way to think of it is with two lights. One unidirectional light (that shines in all directions) and one directional light that rotates at a set speed. When the rotating light points to true north, the unidirectional light will flash. then the rotating light with do one full rotation. then the unidirectional light will flash again. and this continues indefinitely.
    Now, lets assume that the rotating light takes 60 seconds to do a complete loop. If you see the flash, then it takes 30seconds for you to see the rotating light pointing right at you:
    60seconds (total rotation) / 30seconds (time since flash) = 2.
    360 (degrees on a compass) / 2 (from previous equation) = 180(degrees).
    This says you are 180 from north(ie: SOUTH), FROM the lighthouse. ie: you are directly south of the lighthouse. and the light house is directly north of you.
    If you see only one flash, then you are directly north of the lighthouse.
    Hope this helps.
  17. guru200773
    Apr 26, 2010
    94
    thank u very much dude teno45... In order to understand the VOR he said the lighthouse as analogy so posted here thanks a lot dude
