NASA Control Room
Discussion in 'General Electronics Chat' started by daroc26, Jan 18, 2011.
  1. daroc26
    Thread Starter Active Member
    Apr 4, 2009
    30
    Hi All,
    Lately I've been watching a lot of NASA TV and space documentaries on PBS. One thing that is drawing my attention is NASA's Mission Control Center.
    Looking at video from the 60's, mission control had massive computers and at each station there were interfaces with switches, buttons, radars, radios. I am amazed by this and want to learn more about the functions of the stations and instrument panels, and how it was wired and communicated with other stations.
    I've searched a bit to find information about NASA's electronic systems, but I've had no luck. I understand that it's probably classified, but there must be something I could obtain from the public domain, especially technology systems from the 60's/70's.
    I guess I better get down to my question. I want to build an interface, similar to one you'd see in a cigar box or a little bigger, that uses switches and buttons, and offers some sort of output. Hope this makes sense! Any suggestions?
  2. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Makes you wonder what happened to all that old equipment. Would be kind kind of cool to buy the surplus and set it up, if you had the space and the money.
  3. Kermit2
    Feb 5, 2010
    3,854
    968
    That equipment was far less sophisticated than you imagine.
    Glorified security camera console was all most of them were. Those weren't computer stations, but monitors for a primitive CCTV system where cameras looked at different equipment consoles and all the video feeds were sent back to a 'control' room.
  4. marshallf3
    Jul 26, 2010
    2,358
    201
  5. daroc26
    Apr 4, 2009
    30
    Really? It doesn't seem that way. The computers they used for Apollo seemed pretty complex. I can't imagine each operator was simply looking at a monitor.
  6. Rbeckett
    Member
    Sep 3, 2010
    205
    32
    Remember, we went to the moon and back on less power than a commodore 128 back in the day. Most watches have more power than the lunar lander ever had, even now.
    Bob
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    There were a lot of logic being build with transistors. The ICs of that era were less than 20 transistors, and a lot more primative.
  8. blueroomelectronics
    Jul 22, 2007
    1,758
    98
  9. maxpower097
    Feb 20, 2009
    795
    388
    Don't know much about it but I remember hearing on a documentry that the first space shuttle or pod had less power then a modern calculator. Not sure if it was true or they were making a point but I found that amazing.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Lets see, the first shuttle flew in 1982. At that point hard drives were well established, if small (10 and 50 megs). Governments in general could afford the best, so figure 100Meg or more maybe.
    The Z80 was well established, as was the 8080 (released in 1974) and 8086. I would rate this as a myth, unless you are talking about a very high power programmable calculator. Most of those could easily be classed as computers unto themselves.
    The original processor that started it, the 4004 created in 1971, was a 4 bit CPU that all the 80XX series spun off of. Embedded in all the spin offs is the original op code set (modified I'm sure).
  11. tom66
    May 9, 2009
    2,613
    214
    The orginal Apollo guidance computer was constructed from 2,800 three-input NOR gate ICs (RTL logic.) It consumed 55W and operated at 2.048 MHz. A modern calculator doesn't really have a clock (except maybe for the display drive) but the logic inside it probably exceeds 2,800 gates, and typically consumes on the order of microwatts, so it sounds about right.
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    He didn't say Apollo, he said Space Shuttle. Those little details matter.
  13. marshallf3
    Jul 26, 2010
    2,358
    201
    Anything going "up there" is going to be state of the art and that's why we have such a good supply of both new and surplus parts available - research.
  14. maxpower097
    Feb 20, 2009
    795
    388
    I said shuttle or pod. Meaning even pre apollo. So re run those numbers for a 1967-68 launch pre moon landing.
  15. Wendy
    Mar 24, 2008
    20,772
    2,540
    The Apollo never was referred to as a shuttle. Before that was the Gemini, and before that was the Mercury. All of those were capsules, including the Apollo. All of this was during my lifetime and living memory. God I feel old.
    When the Apollo program was started transistors had been invented 7 years previous. Two years after the 1st moon landing the 4004 CPU came out. This is not a coincidence.
  16. thatoneguy
    Feb 19, 2009
    6,357
    718
    From the wiki:
    Original (80s launch era) - 5 computers, 4 running the same task, if one malfunctioned, it was "voted out" by the other 3.
    400,000 instructions per second (16 bit systems), each with 424kB of magnetic core memory.
    This was later upgraded in the quote above.
    In that search, I also found the sad, sad state of our educational system, there was a question about "Why didn't they send the shuttle to rescue Apollo 13?" :eek:
    --ETA: Found the specs on the Apollo Landing Computer:
    Original AGC:
    Designed by M.I.T. in 1964
    World's first microchip computer
    Prototype computer for Apollo moon landing
    Memory: 12K fixed (ROM), 1K eraseable (RAM)
    Clock: 1.024 MHz
    Computing: 11 instructions, 16 bit word
    Logic: ~5000 ICs (3-input NOR gates, RTL logic)
  17. marshallf3
    Jul 26, 2010
    2,358
    201
    I used to have a flight computer from an old fighter jet, tons of boards filled with 2N404 transistors and a ton of core memory cards as well. Probably state of the art at the time just as I found a mobile tracking station at military surplus dump. Sweeping scope that was in sync with the antenna, the technology is even used to this day.
  18. Hagen
    May 8, 2010
    30
    I don't know how historically accurate the movie "Apollo 13" was, but I seem to remember several of the mission scientists using slide rules to calculate critical values.
  19. maxpower097
    Feb 20, 2009
    795
    388
    Too long ago for me. All I remember is the helicopters racing to meet the pod at sea. Thats why I call it a pod.
  20. nsaspook
    Aug 27, 2009
    3,017
    2,378
    A lot of them used specialised rules for fuel flow/burn rates or nav systems.
    They made models for everything.
    http://www.sliderules.info/collection/specialised/9923-brl-nuclear.htm
