Narrow Band Pass Filter
George10101
Joined Sep 25, 2014
Hey, Im looking to create a Narrow band pass filter. I've designed the circuit but i just need to calculate values for the two resistors and capacitors. Between the frequencies of 5KHz and 10KHz is is when i will be allowing current to flow. I am connecting it up on a bread board. Could anyone help me please? My circuit design is attached. Thank you
Wendy
Joined Mar 24, 2008
23,421
The Completed Projects Forum is for Completed Projects only. It is meant to allow members to show plans for projects they built so other members can duplicate them if desired. Your thread does not belong in this forum, and was moved here.
34,408
The corner frequencies of your circuit are 1/(2 pi RC). R1 and C1 determine the low frequency -3dB point and R2 and C2 detrermine the high frequency -3dB point.
MikeML
5,444
Here are three different filters that come close to your requirements. Note the three different response curves (Green, Red, Blue). F3 is the "narrowest".
Dont use 741's. They are a crummy opamp that was obsolete 30years ago...
