Hello forums,
that's my first post, and I hope its not going to expose my complete amateurishness.
I want to take fluorescent measurements, which can be done with phototransistors for example. And the phototransistor will be partly exposed to the excitation light, which comes from an highpower LED (can easily be fed with 1,5 Amps for a short time). Fortunately the fluorescence has a live time of more than 10 nanoseconds (after 5 livetimes the fluorescence has completely decayed). I want to excite the fluorescence with a nanosecond pulse, and then start the measurement by the phototransistor after the LED has been shut down. Idealy the measurement of the phototransistor goes into an integrator, which accumulates the intensity over 5 livetimes.
Thats one cycle.
So my first question is: how can I pulse a highpower LED at pulse durations of less than a nanosecond (i.e at frequencies more than a Gigahertz)? I am fiddling around with raspberrypi and arduinos for the data aquisition. But this measurement cycle has to be done on an external circuitry. Rasperry pi does not tick at gigahertz.
thank you in advance,
kind regards from germany
amrosik
Thats one cycle.
amrosik
