NAND2 CMOS help
Discussion in 'Homework Help' started by geft, Dec 26, 2011.
  1. geft
    Dec 8, 2011
    19
    The question asks to find the threshold voltage for the case where two inputs switch simultaneously. What does this mean?
  2. praondevou
    Jul 9, 2011
    2,936
    489
    Please post the context, maybe the original question with a picture or formula or something.
  3. geft
    Dec 8, 2011
    19
    Consider a CMOS NAND2 gate for the case where the two inputs switch simultaneously.
    Assume k_p = k_n = 100 uA/V^2. Derive an expression for V_{th}.
    It then notes that when both transistors are switching simultaneously, NMOSA is in saturation and NMOSB is in linear region.
    What does "two inputs switch simultaneously" mean?
  4. MrChips
    Oct 2, 2009
    12,652
    3,461
    You cannot get much clearer than that. It means both inputs are changing at the same time.
  5. geft
    Dec 8, 2011
    19
    Would that affect the circuit differently compared to when the inputs are both static?
  6. MrChips
    Oct 2, 2009
    12,652
    3,461
