Nand only expression
Discussion in 'Homework Help' started by Code, Nov 29, 2005.
  1. Code
    Nov 29, 2005
    Hey,
    I want to convert the following expression to NAND2 form, so all terms are in the NAND form
    Z'W+Z'XY+WY'
    = W(Z'+Y')+Z'XY
    A partial solution:
    w (z'+y')+z'xy
    = (w (z'+y')+z'xy)''
    = (w' + (z'+y')' (z'xy)')'
    = w' + (z''y'') (z''+x'+y')
    = w' + (zy) (z+x'+y')
    Is that right so far?
    Is the next step the use of two bars over the (zy)(z+x'+y') terms?
    Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you have a logic template, try working it out as signals applied to NAND gates. Not very elegant, but you can at least see how it works. MIL-STD 806C forever!
    They're easy to draw freehand, too.
