NAND Logic Gate
Discussion in 'Homework Help' started by mechatronics_student, Sep 26, 2012.
  1. mechatronics_student
    Sep 26, 2012
    Hey there!!
    Right now I am stuck with my logic gates homework... The only one that I need to finish it is one application for NAND logic gate... Guys I really appreciate if you can give me Ideas... thank u!!
  2. Austin Clark
    Dec 28, 2011
    409
    44
    Maybe a seat-belt protection thing? If there's weight on the seat (Which we'll represent as a 1), and the belt isn't buckled (Also represented as a 1), the car won't start (0).
    EDIT: Actually, that's a pretty poor example... I'll come up with one better later :)
    mechatronics_student likes this.
  3. MrChips
    Oct 2, 2009
    12,652
    3,461
    Start off by understanding what a NAND gate is.
    It is an AND gate with a negated output.
    Find two conditions that must occur together before something is allowed to happen.
    Now negate the outcome.
    Find two conditions that must occur together before something is disallowed.
  4. mechatronics_student
    Sep 26, 2012
    Actully I understand what is a NAND gate...
    But... I need an example in real life...
  5. WBahn
    Mar 31, 2012
    18,093
    4,920
    So find something where knowing that both conditions are True tells you that some other condition is False (and, otherwise, it is True).
    Putting it in English terms, you might say something like, "This will be false if both this condition is true AND this condition is true."
    Conversely, another way of saying this is to find something (the output) that is dependent on two things such that the something is True as long as one of the things it is dependent on is False.
    Putting this in English terms, you might say something like, "This will be true UNLESS this condition is false OR this condition is false."
    Yet another way to capture this notion in English terms would be, "This will be false if EITHER this condition is false OR this condition is false."
  6. MrChips
    Oct 2, 2009
    12,652
    3,461
    An AND condition occurs in many security checks.
    Your USER NAME is valid AND the PASSWORD is correct -> ENTRY is allowed.
    Now you need to turn that into a negative outcome.
    Your USER NAME is valid AND the PASSWORD is correct -> You are NOT prohibited.
    You can use DeMorgan's theorem and turn that around to an OR gate.
    USER NAME is NOT valid OR the PASSWORD is NOT correct -> You are prohibited.
  7. way2afroz
    Member
    Dec 23, 2008
    22
    how can i make logic gates on bread bord i need help what to buy........
  8. MrChips
    Oct 2, 2009
    12,652
    3,461
    You just hijacked someone else's thread.
