NAND circuit to NOR
Discussion in 'Homework Help' started by nanduko, Oct 31, 2009.
  1. nanduko
    Oct 31, 2009
    11
    Hello everyone !
    So i have to turn this circuit that is made of nand gates into the equivalent of this but this time only with NOR gates. This is the circuit :
    First i tryed to turn the circuit into some boolen algebra statement but nothing happned, actually it became harder =/ i am strungling trying to solve this loads hours ....help me please...
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Take a look at DeMorgan's Theorem.
    hgmjr
  3. nanduko
    Oct 31, 2009
    11
    Well ok De morgan's theorem, but i need an expression 1st for the circuit, there is where i am strungling , i am getting confused all the time....
    This is stupid but anyway... my conclusion is: (((((pp)'p)')'(rr)')')'
    this is not right, right?
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    First observation is that there is no q in your boolean expression.
    Have you noticed that four of the nand gates are configured as simple inverters?
    hgmjr
  5. nanduko
    Oct 31, 2009
    11
    indeed theres no q, it was meant to be like this (((((pp)'q)')'(rr)')')'
    but still not sure if this is .
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    HINT: If you feed the same signal into both inputs of a NAND gate, all that is doing is inverting the input.
    hgmjr
  7. nanduko
    Oct 31, 2009
    11
    yeah i know that, thats why so many '''''' xD
    ill try again and post
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    Using your boolean notation, I get simply:
    (p'q)r'
    because (pp)' = p'
    hgmjr
  9. nanduko
    Oct 31, 2009
    11
    i tryed again in a bit different way,
    isnt it ( (p' NAND q)' NAND (r') )' ?
  10. hgmjr
    Jan 28, 2005
    9,030
    214
    That looks correct although it would be clearer if some simplification were performed.
    hgmjr
  11. nanduko
    Oct 31, 2009
    11
    hmmmm i tried to simplify it a bit, not sure again if its right
    ( (p' NAND q)' NAND (r') )' =
    ((p' q) nand (r') )' =
    (((p' q) (r') )' )' =
    ((p+q') + r)' =
    (p'q) r'
    i believe theres a mistake somewhere
  12. hgmjr
    Jan 28, 2005
    9,030
    214
    If you take a look at post #8 in this thread, you will see that I got the same simplified answer you have in post #11.
    I guess your next step is to implement this boolean expression using NOR gates. Right?
    hgmjr
  13. nanduko
    Oct 31, 2009
    11
    yeah as long as this result is ok for the given circuit, ah btw forgot to mention that i hd already proved that p'q = p nor (p nor q) , the problem is the r' now, should i call for example p'q=d and say r'd = r nor ( r nor d) ?
    Thanks in adance
  14. hgmjr
    Jan 28, 2005
    9,030
    214
    My thought was that if you needed an inversion, you would feed the same signal into both inputs of a NOR gate just as was done in the NAND gate version of the circuit.
    hgmjr
  15. nanduko
    Oct 31, 2009
    11
    indeed i could feed a nor gate with 2x r so the result is r' , but still theres a multiply , how can do that as a nor gate . i mean --> (p'q) multiply r'
  16. hgmjr
    Jan 28, 2005
    9,030
    214
    You do realize that there is not an actual multiply operation involved. That is simply the indication of an AND function.
    hgmjr
  17. hgmjr
    Jan 28, 2005
    9,030
    214
    See if the information at this website helps you out.
    hgmjr
  18. nanduko
    Oct 31, 2009
    11
    ehm lol yeah, i think i finally figured out, ill post the scematic as soon as possible
  19. nanduko
    Oct 31, 2009
    11
    nor version of this (p'q) r' is :
    hopefully
    EDIT: i think that the second NOR (where r entrance is ) is not needed tho.
  20. hgmjr
    Jan 28, 2005
    9,030
    214
    Your diagram has a couple of errors. Take another stab.
    hgmjr
