NAMUR input simulation
Discussion in 'Embedded Systems and Microcontrollers' started by Negativ3, Dec 5, 2011.
  1. Negativ3
    Dec 5, 2011
    Hi All!
    I have an arduino cct I can use for simulating the "shorting" of NAMUR inputs (+/-) to provide a signal input, and it works well.
    I was wondering if its possible to do this in a single, self-contained circuit, drawing power from the NAMUR +ve rail?
    I have ideas of using a 555 to set the pulse frequency, but not sure where to start on the output, shorting of contacts part... drive a transistor off the trigger output possibly?
    Any guidance really appreciated.
  2. Negativ3
    Dec 5, 2011
    Oops, mods, can you please move this to the correct forum? Thanks
  3. Negativ3
    Dec 5, 2011
    Here is the cct I have so far but it's not pulsing to the base of the BC546.
    Sw1 should be continuous mode, frequency set by Sw3 position. Sw2 is for a single pulse.
    Any help appreciated...
