Name of connectors similar to Barrel and JST connectors
Discussion in 'General Electronics Chat' started by NathanielZhu, Dec 23, 2015.
  1. NathanielZhu
    Thread Starter Active Member
    Dec 5, 2011
    50
    I have a few devices with broken connectors and I'm looking to replace this connector.
    I'm not looking to replace it with an exact connector, just one that works.
    I searched 5v Barrel Connector on ebay but the search term didn't yield a very popular selection so I assume this wasn't the most common name.
    All I'm looking for is a connector that has both the positive and negative pins on the same connector.
    I've considered:
    -A simple Female MicroUSB Tabbed Pins and just using the power pins and ignoring the serial Pins)
    -JST pin (Don't really like these since they don't disconnect as smoothly as I like)
    - Barrel Connector (Ideal but searching for an exact fit pair is a bit confusing for me)
  2. MrSoftware
    Oct 29, 2013
    545
    133
    You don't give a lot of details about what you need, but if you want a heavy duty connector that will hold tight then deans connectors are fantastic. They're typically used to connect batteries on flying toys, so they will handle tons of current. Maybe more than you need, but they're solid heavy duty connectors:
  3. Nathaniel Zhu
    Oct 16, 2015
    19
    Thanks for the suggestion.
    I'm looking for a connector that is easily connectted and disconnected and preferably is small.
    I recently acquired a lot of these broken Pipette Guns http://i.ebayimg.com/00/s/MTYwMFgxNjAw/z/TTIAAOSwstxVFMBN/$_1.JPG.
    And all of them have the same problem, the broken connector so I'm considering my options.
    I would like to know if there is a source that can give me an overview of what connectors exist.
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    Photo of broken connector - ?????
  5. JohnInTX
    Jun 26, 2012
    2,393
    1,051
    From the picture it looks like a DC power plug like these from Mouser?
    Digikey has them as well.
    If it looks like the one, you'll need to know the diameter of the pin to find the right family. Pull the datasheet to check the rest of the dims.
    Switchcraft, Kycon and CUI make some good ones.
    If those aren't it, as AK says, post a picture and maybe some measurements.
    Good luck
  6. DanyRoden
    Jan 11, 2016
    Molex and IEC connectors are similar to the Barrel and JST connectors. You can replace them.
  7. fiberstorejames
    Aug 5, 2014
    18
    Do you have the picture of broken connectors?
