Nambour Solar Hot Water
Discussion in 'The Projects Forum' started by solarshine, Dec 31, 2011.
  1. solarshine
    Dec 25, 2011
    Who knows the circuit of a solar panel?
    I have a plan to use a solar panel for my lighting supply for my indoor garden.
    Please give a suggestion about my plan.
    Thank you Guys.
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    Lighting an indoor garden from a solar panel is unlikely to work well unless the garden is very small in relation to the size of the panel. Even with the most efficient available panels and lamps, the total light energy obtained at the output can only be a small percentage of the input. Possibly this would be more successful as a means of extending the day length if the garden receives some natural light during the day.
    Such a setup would normally involve large storage batteries, a charge controller, and a lighting system, probably LED nowadays. I do not think that you will be able to get "a circuit" that will let you do this easily for yourself - you may do better to look into commercial suppliers of solar power systems.
  3. wayneh
    Sep 9, 2010
    12,398
    3,246
    So why does your title mention hot water? Solar water heating is reasonably efficient.
    Conversion of sunlight to electricity in a battery and back again to light is maybe 5% efficient before considering the inefficiency of the LEDs and the wavelength considerations. Shifting wavelength - from unused wavelengths into the right wavelengths for plants - might be a way to gain efficiency overall, but without attention it'll more likely work against you. You'll take good sunlight and convert it to useless light.
    What are you really trying to do?
  4. Bernard
    Aug 7, 2008
    4,242
    418
    At top of page, upper right is a "find" box; put in - grow light - for lots of information.
