Could it possibly be because you are ignoring the advise of the people trying to help you? Substituting things that aren't what your told to use?any help- people - about this illogical problem.?
I have revised the circuit for you to reflect some of the changes you have made. I have added decoupling capacitors. Since the LM358 is such a slow opamp, I simulated the step response, and found the circuit to be marginally unstable, so I have added some additional feedback to add phase margin to make the circuit less prone to oscillation. I have added the gate resistors per suggestion.any help- people - about this illogical problem.?
ok I am working on it , but do you think that this mosfet will do the job because it is written in datasheet that it is good in fast switching . i think that its linear region is narrow.I have revised the circuit for you to reflect some of the changes you have made. I have added decoupling capacitors. Since the LM358 is such a slow opamp, I simulated the step response, and found the circuit to be marginally unstable, so I have added some additional feedback to add phase margin to make the circuit less prone to oscillation. I have added the gate resistors per suggestion.
Try it as shown now. Write back if you change anything...
Not really a problem. We are not trying to build a precision current sink.Since with Mos Fets the gate threshold voltage variation is so large you need an op amp for each one.
I already incorporated that suggestion into the circuit. In the present version, the OpAmp is operated in unity gain mode where it should be unconditionally stable. The settling time will be much slower, but it shouldn't oscillate...If you add 75 or 100 ohms between the output of the op amp and the gate it will restore stability lost when it tries to drive the high capacitance of the FET.
no the one i used was audio pot like this http://www.ebay.com/itm/2x-Audio-A5...d=100005&prg=1088&rk=3&rkt=5&sd=301031813014&Is this the original pot you bought that you ran many more Watts into than it was rated for? If so change it to a new pot and try again. In the simulation, the control range where the sink current changes occupies more than 60% of the range of a linear pot.
That raises the following question: Is the pot you are using a "Linear Taper" or an "Audio Taper" Pot? You should be using a linear one; not an audio pot...
If a FET isn't turned fully on it will heat up. Using a pot directly to set Vgs, in the absence of a current-limiting circuit, is likely to result in a partly-turned-on state and hence excessive heating.I noticed that some Mosfets are burnt up and that is one of the reasons why ?
I have shown you the heatsink that i used and you didn't object , it's big. also i touched it and the heat wasn't high , it was normal.How many times do I have to say this: The NFETs Must be on a HUGE heatsink. If you are burning them up, you don't have a big enough heatsink. Get a larger area heatsink, or blow air across it using a fan, or immerse one end of the heatsink in water or oil.
The NFETs are operated in their linear region. They are dissipating all of the power that an equivalent load resistor would dissipate.
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Jake Hertz
