N-Mosfet circuit driving 3-5V flexinol air valve
Discussion in 'General Electronics Chat' started by swdj25, Sep 14, 2015.
  1. swdj25
    May 31, 2012
    14
    I'm having difficulty driving a flexinol air valve http://www.robotshop.com/en/dynalloy-flexinol-air-valve.html at room pressure (i.e. 1-5psi) and with IRFZ44N Mosfet connected to a PWM pin of 5V Arduino Pro Mini https://www.arduino.cc/en/Main/ArduinoBoardProMini. Here is the schematic with R1 = 1KΩ; R2 = 10KΩ; and R3 = 5.6Ω/5W.
    Valve Standard operation:
    Voltage: 0.8 to 0.975 Volt
    Current: 750 mA
    Resistance: 1.3 Ω
    Valve performance:
    Operating voltage: MIn. 1.6V ON/ Max. 5V
    Current draw: 0.8 - 2.5A
    PDM frequency: < 5kHz
    Flow rate: 3.0 ft3 / min (typical)
    Response time: < 0.2 sec ON/OFF
    Though the schematics shows that the valve is connected to a pwm pin of the microcontroller, I did test both pwm and digital operations on the software part and they both are not working.
    Any suggestion is much appreciated.
    s.
  2. swdj25
    May 31, 2012
    14
  3. Alec_t
    Sep 17, 2013
    5,968
    1,135
    What do you mean by "standard operation" and "performance"? If you are applying only 0.8V to 0.975V to the valve and it needs a minimum of 1.6V it's not surprising it won't work ;).
    Is your supply able to provide 2.5A, and with a 3A limit?
    The turn-on threshold for a IRFZ44N can be as high as 4V, so a 5V supply may not turn it on fully.
    swdj25 likes this.
  4. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    The circuit you have uses a PNP bipolar transistor.
    If you want to substitute an n-channel MOSFET, the source should go to ground, the drain to your valve, and +5V supply to the other end of the valve. The IRFZ44N can work driven from an Arduino, but you should just drive it directly - leave out all the resistors in the circuit. The response time of the MOSFET will be slow in electronic terms when driven with only 4.5 to 5 volts at the gate, but should be plenty fast compared to your valve's reaction time of 200 mS. If you plan to do pulse width modulation to control the valve, I'd say go back to either an NPN or PNP transistor instead of MOSFET - that will heat up less when driven in the low kHz range with only 4-5 volts.
    Edit: at a later time, you can choose a resistor to put in series with the valve, if desired. Also, your 5 volt supply needs to be hefty to drive this valve, which apparently can take as much as 2.5 amps - that's a lot more than the typical Arduino supply.
    cmartinez and swdj25 like this.
  5. swdj25
    May 31, 2012
    14
    @ Alec_t
    I copied the infomation under "standard operation" from the datasheet http://www.robotshop.com/media/files/pdf/electrostem(tm).pdf
    and the "performance" form the infomation written on the package.
    The power supply I'm using is an AC-to-DC adapter rated at 5V/2.5A.
    I tested the IRFZ44N in the same schematic with a high voltage LED as load and it worked.
  6. swdj25
    May 31, 2012
    14
  7. swdj25
    May 31, 2012
    14
    I have made some correction on the schematic with n-channel MOSFET. I have ordered an NPN transistor and will test it soon.
  8. ScottWang
    Aug 23, 2012
    4,925
    777
    1. You better change to other N mosfet when Rds(on), Vgs=5V, this IRFZ44N, when the Rds(on), the Vgs=10V, it is not good for the uC to drive it.
    2. The current limit resistor, the value as R_limit = (5V-(750mA*1.3Ω))/750mA = 5.367Ω
  9. swdj25
    May 31, 2012
    14
    What other N mosfet would you suggest?
    I have ordered TIP120 n-channel transistor and will post the feedback soon.
  10. swdj25
    May 31, 2012
    14
    Thanks for the calculation.
  11. ScottWang
    Aug 23, 2012
    4,925
    777
    Here are some n ch mosfet, you can comparing the price and which one you easy to get.
    IRL520N_Nch_100V10A_Vgs4V_180mΩ.pdf
    IRL530_SiHL530_Nch100V11A_Vgs5V_160mΩ_vish.pdf.pdf
    IRL540_Nch_100V28A_Vgs4V_77mΩ.pdf
    PSMN017-30PL_Nch30V32A_17mΩ_Logiclevel.pdf
    CSD16325Q5C_Nch25V33A_1.7mΩ_Logiclevel.pdf
    NTE2987_Nch_100V20A_90Ω_Vgs5V_LogicLevel.pdf
    swdj25 likes this.
  12. Alec_t
    Sep 17, 2013
    5,968
    1,135
    The LED voltage is largely irrelevant. How much current was the LED drawing? It would need to be at least 500mA for a valid test.
    swdj25 likes this.
  13. swdj25
    May 31, 2012
    14
    It was just a 30mA so not the way to test the FET gate I relised.
  14. swdj25
    May 31, 2012
    14
    flexinolValve_5vArduinoProMini_MOSFET_noFetResistors.jpg @ Roderick Young
    I have attached an updated schematic without resistors between the FET gate and the MCU and leave the limit resistor in series with the valve, is it correct?
  15. Alec_t
    Sep 17, 2013
    5,968
    1,135
    That looks ok, provided your FET switches on fully with 5V on the gate. But as far as I can see from the quoted figures, the valve will be only slightly open at 800mA.
    Roderick Young likes this.
  16. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    That's what I had in mind. Looking at the curves on the datasheet for the IRFZ44N will work in your circuit with a 5V gate drive. You just don't want to do your pwm at faster than about 1 kHz, or you will be wasting a lot of power in the MOSFET as it slowly turns on. With a 10V gate drive, the transistor will turn on faster, and frequency is less of a concern.
    I'm not sure how that valve works. If it's not just a simple open/closed sort of thing, then maybe you're trying to control how far open it is? In that case, I would use NO resistor in series with the valve, and regulate the amount of power going to it with pulse width modulation. You might also need to put a capacitor in parallel with the valve to keep it from chattering.
  17. Alec_t
    Sep 17, 2013
    5,968
    1,135
    My understanding is that the applied voltage heats a wire whose length varies with temperature to adjust the valve opening amount.
  18. swdj25
    May 31, 2012
    14
    Yes, it's a nitinol wire but I have no idea what diameter it is.
  19. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    I see. The main thing is that it's continuously variable, and not an on/off thing like a solenoid. In that case, I'd say definitely leave out the series resistor, and control the amount of valve opening by adjusting the duty cycle of the driving waveform. That will be more efficient, too.
