I have a N-Mos driven at 40Khz gated at 2Hz by a 555-based driver. It's driving a monitor flyback transformer using the low-side configuration. I worked the circuit for spans of 4 seconds. Power for the FET side is 70V PDC. the Gate voltage is 9v so both are well below what their datasheets put max values at.
Sadly, I burnt it.
There is no pull down resistor for the FET nor a resistor-diode snubber for the primary of the flyback. The FET has a sink and a fan nearby blowing at it.
Before you stomp at me for negleting these, I noted something.
I wired up everything religiously, but left the FET driver disconnected [so FET is OFF]. I found that a current of 0.7A flowed. No, the FET was good...I tested with another fresh one. Both had this happening.
I replaced the flyback with a normal 12v 0.3A computer power supply fan and the flow was absent. In theory, regardless of the presence of a worthy load or a short circuit, this flow should not happen...but in this case it is.
Why is this?
Sadly, I burnt it.
Why is this?
