N Enhancement Logic mosfets
Discussion in 'General Electronics Chat' started by André Ferrato, Jan 15, 2016.
  1. André Ferrato
    Apr 5, 2015
    206
    Hello, i intend to buy a few of these little guys from china or ebay, as it takes like 2-3 months to reach my country i first buy them and after i bought i learn about them. Could someone point me to some nice pieces of hardware? Oooh and please TO-220 case, breadboard friendly.
  2. nerdegutta
    Dec 15, 2009
    2,569
    806
    Hi.
    To be clear: Do you want to buy N-channel mosfets?
    If so, you have DigiKey, Mouser, Jameco, and a bunch of others.
    It would also help if you say what country you are in, or at least which part of the world. :)
  3. André Ferrato
    Apr 5, 2015
    206
    Yes, the logic ones, that are fully on at only 5v. N channel enhancement, and it must be from ebay or aliexpress, that's why i need the name of the mosfet. I live in brazil.
  4. #12
    Nov 30, 2010
    16,705
    7,355
    Not if you mean the plastic boards with holes to plug things into. They don't fit TO-220 leads because they are too fat. You will have to solder a bit of wire to each lead in order to get them to plug in without damaging the practice board.
  5. nerdegutta
    Dec 15, 2009
    2,569
    806
    OK, then I'd look into Digikey and Mouser, and see if I found the part on their site. If so, I'd go to eBay or Aliexpress, and look for the same part.
    And @#12 has a valid point. If you have a thight new breadboard, you'll struggle, but if the board is well used and loose, then it might work. You might need a heatsink.
  6. André Ferrato
    Apr 5, 2015
    206
    Mine does, or it's already damaged :eek:, but nevertheless, that would suitable for my purposes. I have three breadboards, two of them are so tight, but one is like "made" for these packages.
    I'm asking here because i get really lost through all that data. And you guys had more experience than me, so it's like asking a person the best route to a place.
  7. #12
    Nov 30, 2010
    16,705
    7,355
    There are thousands of N-ch mosfets, even in the Logic Level type. We can guess that your voltage is less than 30V and the current in a breadboard is under 2 amps, but it would be nice to hear from you about that.
  8. André Ferrato
    Apr 5, 2015
    206
    Oh sorry, i didn't knew that. Yes current is less than 2 amps and voltage is under 12v. I need one that is completelly on with 5v, but now i feel that my question envolves many variables.
  9. RichardO
    May 4, 2013
    1,342
    431
    The trick to plugging TO-220 into a solderless breadboard is to give the leads a quarter twist before plugging them in.
    Edit: Oops, again... finger was too fast and too clumsy-- meant quarter not half.
    absf and #12 like this.
  10. GopherT
    Nov 23, 2012
    6,326
    4,055
    I just push harder. I usually keep them on one end of the board reserved for such abuse.
    absf likes this.
  11. #12
    Nov 30, 2010
    16,705
    7,355
    nerdegutta likes this.
  12. André Ferrato
    Apr 5, 2015
    206
    Hmm, that's a good point to start, thanks a lot @#12 .
    My breadboards usually fit almost everything, that's not a big deal for me. But, yes, sometimes i pick my pliers( i ain't sure thats the word for what i'm looking for) and pinch the pins, weakly.
  13. #12
    Nov 30, 2010
    16,705
    7,355
    My breadboard is so stubborn that I use the piers to jam 22 gauge wire in!:mad:
  14. nerdegutta
    Dec 15, 2009
    2,569
    806
    Do you have one breadboard? :D I got breadboards all over the place. Some need the gentle touch of an angry pliers.
  15. André Ferrato
    Apr 5, 2015
    206
    It's possible an asian breadboard.
  16. nerdegutta
    Dec 15, 2009
    2,569
    806
  17. André Ferrato
    Apr 5, 2015
    206
    IRLZ44N
    This one seens really cheap and maybe good. How about?
  18. #12
    Nov 30, 2010
    16,705
    7,355
    Good transistor, bad price at 4X what you can get from a reliable vendor of top quality parts.
    See post #2
  19. André Ferrato
    Apr 5, 2015
    206
    Bad price? This is 10 pieces ! Each one costs 1.28 dollars if you buy 10 at mouser.
  20. #12
    Nov 30, 2010
    16,705
    7,355
    Oops. I missed that.:oops:
