N-ch Mosfet characteristics
Discussion in 'General Electronics Chat' started by Col16, Feb 5, 2015.
  1. Col16
    May 2, 2013
    Hi there
    I am looking for some assistance in understanding the Vds waveform I measure when switching off an N-ch enhancement mode power mosfet. The transistor is simply switching off a filament lamp that draws about 5A from the 12Vdc supply. The waveform attached has Vgs on channel 1 and Vds on channel 2.
    I am thinking that the spike and discharge curve is due to some parasitic components of the transistor. The transistor is being driven very quickly with a 4A driver with no gate resistor.
    Has anyone ever seen a similar voltage at the output that can shed some light on the cause?
    Any help is much appreciated.
  2. crutschow
    Mar 14, 2008
    13,482
    3,370
    There appears to be some inductance in the circuit.
    Post a schematic and picture of the circuit if you can.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Don't wound filaments look like tiny inductors?
    Twinkle, twinkle little star,
    V is equal L(di/dt)
    OK so it doesn't rhyme.
  4. crutschow
    Mar 14, 2008
    13,482
    3,370
    Filaments would have a tiny inductance but I doubt it's sufficient to give the voltage spike he is seeing. ;)
  5. tindel
    Sep 16, 2012
    576
    196
    Yep - inductive kick from your current turning off so quickly. try to put some resistance on the gate to limit the turn on / turn off current.
