N.C. pushbutton SET/RESET switch
Discussion in 'The Projects Forum' started by alexa-lol, Dec 6, 2009.
  1. alexa-lol
    Nov 22, 2009
    5
    hej :) I am working on some project. I have to make some circuit. The circuit would turn LED on/off, it would invert the state of the LED (0->1 or 1->0). The problem is that I have to use NC pushbutton switch.
    I have made a circuit.. It works but not as well as I want
    How could I achieve this effect?
    thanks
    cheers
  2. eng1ne
    Member
    Dec 4, 2009
    97
    Have you considered using transistors and opamps for your application?
  3. mik3
    Feb 4, 2008
    4,846
    63
    What is the circuit expected to do?
    I guess the push button is the white square in the diagram, isn't it?
  4. alexa-lol
    Nov 22, 2009
    5
    No I have not considered it because I want to make it from gates. I am sure its very simple.
    Well yeah..
    The white square is the button. If the LED is on the switch turns it off and if it is off it turns it on.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here's an idea for you.
    See if you can figure out how to adapt it to a NC switch.
