Hello can someone look at this circuit diagram which has a mosfet oriented backwards? this is part of the power supply circuitry in an Olimexino (arduino) board that is designed to run off either a usb connection or a wall wart power supply.
the component FET1 is a pmosfet that is configured so the current will flow from the drain to the source in the absence of a power input at the left-side connector. the "+5V" line is the main power bus on this board. this is from the Olimex website. i've used this board extensively and have never seen a typo on the schematic. am i loosin it? why would the fet be oriented like that?
