Mystery Fuse Resistor...I'm stumped
Discussion in 'The Projects Forum' started by qu1j0t3, Mar 28, 2016.
  1. qu1j0t3
    Mar 28, 2016
  2. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Good thinking Batman..................................
    If its in series with a load; its probably less than 1R or not much more. If there are outputs less than 3.3V, a 12R bleed resistor would make more sense.
  3. qu1j0t3
    Mar 28, 2016
    Digikey had no fusible resistors in stock when I checked. Could you post a screenshot?
    When I said "almost identical" I mean the circuit is almost identical in spec and purpose and layout. It seems likely the resistor spec is similar; I certainly have no better pointers than this thread. In my case all bands were obliterated.
