Mystery component!
Discussion in 'General Electronics Chat' started by jut, Aug 16, 2010.
  1. jut
    Thread Starter Senior Member
    Aug 25, 2007
    224
    I'm trying to figure out what this component is. It has this label:
    CD
    A10CA
    The "CD" part must be the logo of some company, see the attached drawing please.
    The part is shaped like a through-hole diode (black, cylindrical, leads coming from either end), except that it doesn't have the line to indicate the "negative" side of a diode.
    If someone can find this part, I'll paypal you a couple bucks. :)
      File size:
      683 bytes
      12
  2. retched
    Dec 5, 2009
    5,201
    313
    Can you post a photo of it?
    Is it a fuse?
  3. jut
    Aug 25, 2007
    224
    I don't have a digital camera handy, but it looks like this:
    http://media.digikey.com/photos/Diodes Photos/31-DO-201AD.jpg
    ...EXCEPT there's no white ring around the left end as a diode would have. It's about the same size as a 1n4001 diode though.
    I measured the resistance across it's terminals in both directions; both times my DMM reads about 1 ohm. It could be some kind of sense resistor.
  4. sceadwian
    Jun 1, 2009
    499
    37
    If it were a resistor the markings would be much simpler and the casing wouldn't be black and shaped like a diode.
    A real picture of the actual device would provide tons of information.
  5. retched
    Dec 5, 2009
    5,201
    313
  6. jut
    Aug 25, 2007
    224
  7. marshallf3
    Jul 26, 2010
    2,358
    201
    Take an inductance meter and see if it has any to speak of, at 1 ohm DCR it probably will.
