Mysterious MOSFET...
Discussion in 'General Electronics Chat' started by FBorges22, Jun 3, 2009.
  1. FBorges22
    Thread Starter Senior Member
    Sep 11, 2008
    108
    Greetings,
    I am looking for a mosfet similar to the IRF1404 but in P-channel version to be used in a class D amplifier. Anyone knows a part number that meets this?
    Thanks,
    FBorges22
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A parametric search on the IR web site turns up nothing. The 1404 is not likely to have a P channel compliment.
  3. balisong
    Member
    Feb 26, 2008
    27
    You could check out SUM110P04-05 from Vishay. If you need the FETs really well matched, you could use another IRF1404 with a high-side driver.
  4. FBorges22
    Sep 11, 2008
    108
    What pair of P-ch and N-ch should I use to build a good class D amplifier? I need a drain current of 30A RMS and the mosfet need to be enhanced type.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  6. mik3
    Feb 4, 2008
    4,846
    63
    It is not necessary to use a p-channel MOS. You can use an n-channel one with a high side driver IC.
