I was just soldering and that bloody thing fell off....
I was like Son Of a .....
It was the tip that broke, I mean the whole thing is the tip. Unlike other irons, this one's tip is different.
The whole metal part u see is the tip, just pul it outnd put a nother one in...simple. ..One problem.........It's the only one I got for now..
Now I feel like both of my legs are gone..I got no way to solder.
Even to make a iron I need an iron ....
Oh, didn't you read the owner's manual? The tops of those tips are soldered on using 50/50 tin/lead solder. So, you have to keep the temperature just right, if you want it to stay in one piece.
That's surprising for a Hakko station, they aren't cheap rip-offs...
I've never had that happen with a soldering iron but I've had the entire tip assembly come off the iron's heater, luckily it screwed back on (possibly not fitted properly at the factory.)
I had an iron break altogether once.
I just sat and stared at my circuits for a good 20 minuets...
Do you have a desoldering iron that could be used as a soldering iron?
I did that once by removing the desoldering tip and wrapping a normal tip in pie-pan material so it fit.
Solder station 942 is discontinued and the T2 series tips that go with the 912 hand piece are also discontinued but you can use T12 series tips if you add the long nipple accessory to your 912 hand piece.
I have called Sy, waiting for his reply. I will PM you as soon as I know the answers to provide. I am going to see if he will accept paypal so you can order your parts.
Talked with Sy Creed today concerning your unit. There is a slight problem, was a patient infringement with the 942 and Hakko discontinued making the unit, nothing for this unit is available in the USA. I know you said something about the price.
Sy said he would give 50 off a FX951 making the price 200.00. If you like this unit and can afford it all you have to do is call/email Hammond Electronics in Florida. They will honor this price.
I am getting ready to upgrade my equipment, I can also see what he will do in a package deal if you like.
