My Tank project (25 amp motor controller help )
Discussion in 'The Projects Forum' started by RobbJohnson, Oct 11, 2010.
  1. RobbJohnson
    Thread Starter Active Member
    Dec 15, 2009
    76
    continued from previous posts (25 amp motor controller help )
    Just thought I would drop you a line and let you know . I changed the Tank to 24 volts with a regulator supplying 12 v to the driver, seperate 5 volt supply for the computer. Works great so far. I have not had a chance to try the new chips. still using the 4n36 design. Getting ready to work on the azimith and elevation circuits so I will probbally try then new chips. If i get a chance i git some video of the test on the ground and post it.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Coolness, looking forward to it.
