This talkbox can switch from the internal driver output (through the tube that would be hooked up to it), or it would be switched to the internal 5W amp output going to a speaker cabinet. It also has a non-switchable connection from the input, to a preamp output jack, to plug into my rack rig. Really the 5W amp output isn't used by me.
I would like to instead, be able to toggle switch between the "talkbox" mode and the PREAMP output. I can re-route the input circuit to the switch.....but, on the switch, there is a jumper (under the left red arrow). This is only jumping ground. No matter what the toggle mode is, the ground is always there. I don't understand why a jumper can't be used instead, right on the pc board where the 2 black wires attach underneath. I could free up half this switch to make my mod work.
My only question is about that jumper being wired on the switch. Is it a bad idea to simply jump those points on the pcb?
