My project idea (early concept)
Discussion in 'The Projects Forum' started by tom7891, Oct 2, 2011.
  1. tom7891
    May 16, 2011
    26
    Okay, so i've just started my BTEC electrical course and i've been asked to make an original electronic product. The idea i've come up with is an item tracker for when items are lost in the house. I'll go through my idea before askng the question.
    The main part will be a remote control of sorts. This control will have maybe 5 buttons each corresponding to a tag on an item. The tag will be a simple infra red reciever. The control will use infra red and will beep if pointed at the tag's general direction, but only if the button corresponding to the tag is pushed. The general idea is that you point the remote around the house until it beeps, giving an idea of where the item is (which has one of these tags stuck to it.)
    So, coming back to my question. Well two questions actually. Is this idea actually doable and how can i make these tags as small as possible?
    Sorry about being vague, but i've literally just came up with this idea :p
  2. wayneh
    Sep 9, 2010
    12,405
    3,256
    IMHO, IR is not a super choice for this since the device needs to "see" the remote. Most of my lost items are lost because they're NOT in plain sight, cellphone under the newspaper, TV remote slipped under the sofa cushion, etc. Something that could cause a chirp when queried would be useful. Trouble is power. You need something that uses almost no power until it's asked to respond to your remote.
  3. tom7891
    May 16, 2011
    26
    hmm, didn't think of that. Could be quite tricky...
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Do you live alone?
    Most uCs have interrupted inputs (I know PIC does). They are powered off until the input is energized or de-energized.
    A friend of mine used a solar panel to wake his automated sprinkler at night.
    A piezo-speaker could energize the PIC each time you make a noise. Even better, with a filter it could respond to certain frequencies. In a noisy environment however that wouldn't work.
    Other options could be light (or lack of).
    The size will be an issue though.
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    I would think this probably needs to be a radio application. A protocol where the receiver "sleeps" most of the time, but "wakes" say for a few milliseconds every few seconds might keep the power consumption down.
    Your transmitter would need to squawk the tag address repeatedly, at a rate such that a full address would soon fall into one of the tag's waking moments.
    Depending on your course requirements, would it be acceptable to make a scaled-down version using an IR link instead of RF, accepting that it would be less functional?
  6. tom7891
    May 16, 2011
    26
    Yeah, radio waves was my other thought. I don't think there are any boundaries electronics wise.
    Another thought i came up with was RFID, not sure if it would be practical though. The remote could have a cheap reader built in, and the tags could be rfid tags?
  7. someonesdad
    Jul 7, 2009
    1,585
    141
    Also do a web search; there have been a number of products over the last couple of decades that do this; IIRC, they used RF for the task.
    Me, I just use the UFD.
    (Uterine finding device for those of you not shackled to a SWMBO).
  8. Adjuster
    Dec 26, 2010
    2,147
    300
    A system using passive tags, or tags powered solely by incident RF would get around the problem of battery life. The sweeper would then have to be a bit muscular though, and you might have compatibility/interference/licensing issues.
    Visions of unfortunate effects on some poor soul with a cochlear implant or a heart pacemaker, as we scan for our lost car keys. Perhaps it's worth looking into what frequencies and power levels are acceptable.
  9. Adjuster
    Dec 26, 2010
    2,147
    300
    Oh, and by the way, congratulations for coming and asking an intelligible question about a project, with sufficient detail that we can begin to think about it. Many people come with questions so poorly expressed that they are an annoyance.
    I probably won't be able to help you much more with this, but good luck with it!
  10. tom7891
    May 16, 2011
    26
    Yeah, the pace maker issue is a bit of a problem.
    May ask if infra red will be ok. Can you have different strengths of infra red signals?
  11. #12
    Nov 30, 2010
    16,705
    7,358
    It was called a cat tracker when I bought one, several years ago. I gave it to my sister to attach to her glasses. Click, beep, "There's my glasses!" Much like the "find" button on my battery operated telephones. Click, beep, "There's my phone!"
  12. tom7891
    May 16, 2011
    26
    thanks for the help.
    I'm going to look into rf, see what the lecturer thinks. If there is a problem, i'll stick to infra red.
