my phone indicate that is charging but no battery level increased_
Discussion in 'Technical Repair' started by Htin Aung, Jul 21, 2016.
  1. Htin Aung
    May 29, 2016
    21
    Hi everybody..
    I had a problem on my charging my android phone.
    Although my phone indicating that it is charging no battery lavel is increased.
    I notice that and charge my phone for several hours there is no change.
    Can anyone help me for main solution and reasons?
    How can I repair?
    If there is a problen with my adapter and usb cable?
    When I charge another phone with this USB cable, it is normally work.
    I got a simple way that I changed my USB cable.
    I wanna know is what problem is happen with my phone and USB cable.
    Thanks you.
    I´ll waiting for your replies.
  2. BR-549
    Sep 22, 2013
    2,181
    419
    "When I charge another phone with this USB cable, it is normally work."
    Is the other phone, the same kind of phone? If it is, can you swap batteries and see if the problem follows the phone, or if the problem follows the battery?
  3. Htin Aung
    May 29, 2016
    21
    What do u mean
    What do u mean sir?
    Don´t u understand?
    I wanna know only actural answer.
    I want u to answer my problem.
  4. #12
    Nov 30, 2010
    16,704
    7,350
    The actual answer is that you have to try a different battery. If that fixes the problem, the battery was bad. If it doesn't fix the problem, the phone is bad.
  5. BR-549
    Sep 22, 2013
    2,181
    419
    Htin Aung, I do not know the correct answer.
    But if you have two of the SAME phones, you may substitute battery and cable configurations to find out.
    With the information given, that's the best I can do. Good luck on your studies.
  6. JoeJester
    Apr 26, 2005
    3,402
    1,222
    Try a different charger. Can you charge the phone from your computer's USB port?
