My PCB Drill
Discussion in 'General Electronics Chat' started by R!f@@, Feb 15, 2012.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,785
    771
    Project or not I do not care, but it's about time I make one.
    Since I got me 0.8mm Drill bits from ebay, I can't wait to drill the pcb Jens made me.
    I took apart my little drill and for the time being the Motor mount is finished. The Laser cutter comes handy. :D
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    The mounting looks really nice.
    Is it acrylic glass?
  3. R!f@@
    Apr 2, 2009
    8,785
    771
    It's Acrylic 10mm Plastic.
    Now I need to come up a way to make the vertical moving mechanism.
    U know I see a little wobble at the drill bit tip, not the chuck. Chuck and motor is fairly well aligned I must say.
    The bit shows a bit of wobble..
    Will this effect the drilling hole size as such ?
  4. nerdegutta
    Dec 15, 2009
    2,565
    805
    Depends on how big the little wobble is.
    When I drill my PCB's I put i small piece if tape on the drill bit, to blow away the PCB stuff coming when I'm drilling. When I start the drill, it wobbles a little bit, but as soon as the drill hits center of the hole I'm drilling, it aligns just perfect.
    Just be careful that the barings in the shaft don't get destroyed.
    BTW I have a Dremel in a stand.
  5. mcgyvr
    Oct 15, 2009
    4,783
    973
    Yes any tool deflection or runout can/will effect hole sizes.
    Now get some real acrylic cement (Weld-On #3 and a syringe) and ditch that super glue junk. :)
  6. R!f@@
    Apr 2, 2009
    8,785
    771
    It is very little...I don't think I am saying this right. U see I notice this with my mag glass. I look at the drill bit tip and turn on the motor the bit does not rotate on it's ummmm....:confused:.."idle axis" , and I can see the bit tip a itsy bitsy bigger when it rotates.....
    get my point.? :D
    Come again ? :confused::confused:
    {ed}
    Aaaaah! the glue in the picture.....
    Bullocks ..I bought it from the infamous US hardware store "Ace hardware" and it ain't super glue dummy. it's a two part super glue. An activator and a primer type one...Neat.
  7. CoolBeer
    Mar 29, 2010
    40
    6
    That's clever! I'm stealing that! :D
    Kolbjørn
  8. R!f@@
    Apr 2, 2009
    8,785
    771
    U can't ...it's patented. or copy righted or whatever
    Jens...u can sue him if u like :D
  9. mcgyvr
    Oct 15, 2009
    4,783
    973
    #1 yeah its VERY common for a small bit to not be perfectly straight. Which is what you have.. Will it effect the hole size.. yes very..very slightly.
    And with weld-on #3 and a syringe you won't see the glue marks (ghosting cloud around the parts) at all like you can see in your picture. When done right you can't tell that the parts are glued at all. Its 100% seamless like the pieces were made that way. I'm really just giving you crap and I just LOVE cementing acrylic parts/boxes,etc... I've done a few fish tanks and am addicted to a perfect weld/cement line with no air bubbles,etc... Its really neat..You put the parts together in their final spot and then using a syringe filled with the adhesive right at the edge and the adhesive will just suck itself right into the gaps and disappear.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Me too. It is a much more stable arrangement.
    I wonder if Rifaa could mount it vertically. Making a stable z axis is much easier than trying to come up with a XY table.
  11. R!f@@
    Apr 2, 2009
    8,785
    771
    Aah !, Actually the glue is fr something else. I have pictures but dunno if I would post it. I am fixing an Alien Ware lap. It's hinges are broken.
    And abt the glue. The Plastic is not glued with what u think I did.
    It is glued using chlorophome. The kidnapping thingy used in Hindi films
    But it too works like ur glue. I think I used too much
  12. BillB3857
    Feb 28, 2009
    2,402
    348
    Not to hijack, but where do you get the Weld-On #3?
  13. R!f@@
    Apr 2, 2009
    8,785
    771
    Not in Ace Hardware I believe.
    @Bill
    This thing will be vertical. It's a drill press thingy.
  14. mkbutan
    Sep 30, 2008
    270
    16
    yes it will
    reduce the length of the drill bit push it little in side then it won't wobble
    or may be it's not 108°.
  15. mcgyvr
    Oct 15, 2009
    4,783
    973
    I got mine from mcmaster.com.. Then got the syringes at the local "southern states" its a redneck farmer store and the syringes are for giving medication to farm animals..they had tons of sizes,etc.. but they wouldn't let me buy syringes from the pharmacy without a prescription.. I guess I look like a heroin addict or something. ;)
  16. shortbus
    Sep 30, 2009
    4,082
    1,663
  17. R!f@@
    Apr 2, 2009
    8,785
    771
    Now tht's more like it. A Reply I was hoping for.
    I bought 3 bearing today and am drawing up some sketches. Got short on budget. Freakin' Importers...they have raised the prices of 'em bearings too :mad:.
    I don't think this thing will end up the way I started it. :D
  18. luvv
    Member
    May 26, 2011
    186
    31
    Will it have a foot operated speed/downfeed?
  19. R!f@@
    Apr 2, 2009
    8,785
    771
    Now you have said it.....
    Oh Crap !.....
  20. nerdegutta
    Dec 15, 2009
    2,565
    805
    So now you have to build it?
    build it
    build it
    build it
    :D
    Guess you need some PCB's? Have you decided which schema to use? Yours or t06afre's?
