My PC Desktop not showing Icon.
Discussion in 'Computing and Networks' started by RRITESH KAKKAR, Nov 14, 2015.
Thread Status:
Not open for further replies.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    Hello Guys,
    My PC Desktop not showing Icon.what is the problem.
  2. hexreader
    Apr 16, 2011
    250
    82
    You forgot to turn your PC Desktop on?
    In future, please provide better information when you request help.
    (sorry - I know I am being rude - can't help myself)
    EDIT: OK you put me to shame (again) - you give me a "like" when I am mean to you. I admire that :)
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The Desktop is showing only wallpaper no icon like My computer other software icon. Window 7 64 bits
  4. BR-549
    Sep 22, 2013
    2,167
    416
    Does it show the taskbar?
  5. Ramussons
    May 3, 2013
    561
    92
    1) Is it a New Installation or Was it working OK earlier?
    2) Did you change something about the Screen resolution?
    3) Did you try a Hard Reboot?
    4) Did someone else play with the PC resulting in this?
    5) ...
    6) ...
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    yes it is showing
    No it was working fine earlier for past week it is now showing desktop icon.
  7. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Hello hexreader,
    Do you work in Robots ??
  8. tom_s
    Member
    Jun 27, 2014
    287
    342
    what is the operating system?
  9. hexreader
    Apr 16, 2011
    250
    82
    No, I just like Daleks. (ahh - I get it now - I guess the Dalek creatures Do work inside robots :) )
    I service old equipment (not PCs) for a living - but will retire very soon.
    Thank you for being patient with me :)
    RRITESH KAKKAR likes this.
  10. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Window 7 64bit
  11. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    Try browsing around for the Desktop folder for your user name, and see if the links are in there. If not, it's possible they got deleted. Or maybe your desktop folder is not where you think it is. I'm assuming that you already checked for malware and viruses, and there are none. By any chance, did you run "clean up desktop icons" recently?
  12. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    What to do now?
  13. djsfantasi
    Apr 11, 2010
    2,900
    872
    Have you tried right-clicking the desktop and selecting "Arrange Icons by" and clicking "Show Desktop Icons"?
    Roderick Young likes this.
  14. spinnaker
    Oct 29, 2009
    5,065
    1,162
    If you had two monitors attached at one time then the icons could be displaying in that space. Djsfantasi's solution should fix that.
    If that doesn't do it:
    1. Check the Recycle Bin
    2. Make sure you are logged in under the same account when you created the icons.
    3. If some or all applications are missing from All Programs under Start on the task bar then this is a good indication you are logged in on a different account.
    4. All of the users will be found under C:\Users. Any icons will be found under each name in the Destop directory. If they are not there and not in the Recycle bin then they are gone.
  15. joeyd999
    Jun 6, 2011
    2,756
    2,916
    oooh! oooh! me! me!
  16. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The option of Arange icon is not there.
    when i install other software in 2 account it is showing desktop icon
  17. spinnaker
    Oct 29, 2009
    5,065
    1,162
    Right click on the desktop. It is there. Did you check the other things I mentioned?
  18. BR-549
    Sep 22, 2013
    2,167
    416
    Win 7 Pro SP1 64 bit. Right click desktop. Highlight “View”. Scroll down and click “Show Desktop Icons”.
    Now......right click desktop again. Highlight “View”. Can you see “Arrange Desktop Icons” now?
  19. Natakel
    Oct 11, 2008
    50
    9
    Have you made any changes or added any new software recently?
    If you haven't turned it off, your system restore feature should still be running. Try a restore point for a day prior to the problem appearing.
    Go to Start> All Programs> Accessories> System Tools> System Restore
    Follow the instructions. If a restore attempt fails, start the PC in "Safe Mode with Command Prompt" and type in rstrui.exe at the prompt, and wait for system restore to start. It can take a while on some computers.
  20. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    i have restore the computer by this method it is not working the icon are hiding in this by switch user it is showing icon!
Thread Status:
