My new "5.75HP" Shopvac
Discussion in 'General Electronics Chat' started by strantor, Dec 9, 2013.
  1. strantor
    Thread Starter AAC Fanatic!
    Oct 3, 2010
    4,302
    1,989
    I just bought this shopvac. It claims 5.75hp. Hmmm... Let's do some math. 5.75*746= 4300W. 4300W/120V= 36A. So this thing should only be able to work on a 40A breaker. But what 120V load is on a 40A breaker? And what does a 120V 40A outlet look like? The shopvac's cord plug has a regular 15A pinout. I'm thinking this thing is over rated by a factor of 4 at minimum. I couldn't get it to trip a 10A breaker no matter what I tried. Grossly false advertising.
    Of course I'm ignoring the elephant in the room; There is the work "peak" there. So I get it, that's not constant running HP. But still, it obviously never "peaks" in any mode of operation or else the breaker would trip. So are they taking inrush current, multiply by (120V/746W), and calling that "peak HP?" That's a completely meaningless number!
    Now, further damning this claim, are they talking input power or output power? I figured they were talking electrical HP (input power) but if they're talking mechanical output power, that's even worse. I'm going to plug this thing into my killawatt and see how much power it actually draws. When I search for "universal motor efficiency" I am seeing estimates between 55% and 70%. I'll call it 55%. We'll see how much output power this thing ACTUALLY has.
  2. wayneh
    Sep 9, 2010
    12,361
    3,220
    Yeah, I think they make some calculation of power required to stop the rotation of all moving parts or something goofy like that. Totally irrelevant to the user.
    It would be so easy to introduce some standard measure in this industry, like cfm at a specified vacuum level, but people already know more HP is good, so that's what we get.
  3. inwo
    Nov 7, 2013
    2,435
    315
    Here's an honest report.
    http://www.garagevac.com/The-truth-about-horsepower
    "Most manufacturers of garage vacuums and shop vacuums are marketing their vacuums as 4 to 5 Peak Horsepower (PHP). Lately GarageVac had no choice but to follow this trend."
    GopherT and strantor like this.
  4. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    If you want to measure the maximum current, run it without any hoses or tank on input or output for maximum current draw.
    I think they base it on the RPM factor of around 20Krpm.
    Max.
  5. mcgyvr
    Oct 15, 2009
    4,783
    973
    Says 11.6 Amps max on the specs..
    and that link above states its calculated from the inrush..
    and per UL 1017 the "horsepower" rating cannot be include in the products marking.
  6. PackratKing
    Jul 13, 2008
    850
    216
    " Horsepower " aside, a vacuums; actual performance, is rated on CFM of free air that the little motor / impeller can move...
    Suction from the business end, depends solely upon the amount of air it is blowing out the exhaust, amplified by the size of the orifice / hose / it is pulling that air through...
    Granted, HP. plays a part in making the impeller go 'round, and dogging the suction, makes the motor work harder and draw more amps.
    CFM is generated by the RPM's, distance between the impeller plates, and the number of fins between them...
  7. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Actually an ideal motor, no matter how large, draws 0 power at no load, if you want to measure power you need a load.
  8. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    This is why I suggested maximum load, in a motor driving an impeller fan/pump type load, the load will be maximum when the inlet and outlet are completely Unobstructed.
    Max.
  9. #12
    Nov 30, 2010
    16,655
    7,292
    True. Maximum power in a fan happens when the fan can get the most amount of air into the intake. You'd be surprised at how much a 3/4 inch tall entrance horn will increase the current draw. The "ultimate" vacuum is a function of the design of the fan blade, not so much the RPM. Certain fan blades are designed to "unload" under high differential pressures. The vernacular is that they "paddle" instead of, "scoop".
    Lawn mower horsepower ratings recently got government scrutiny. Mine was rated at 6.5 "reserve powers". After applying the torque rating and the 3100 RPM speed to a math formula, I found out it had 2.75 horse powers. No significant change in 50 years.
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    This is a common problem in advertised specs! That is 5.75 AMERICAN horsepower.
    America has very small horses;
    :D
    shortbus, strantor, #12 and 1 other person like this.
  11. wayneh
    Sep 9, 2010
    12,361
    3,220
    But not in Texas, home of the world's larges horse, of course.
    THE_RB likes this.
  12. strantor
    Oct 3, 2010
    4,302
    1,989
    Numbers are in, verified by killawatt and fluke. With the filter and all hoses removed, it draws 10.8A. With clean filter, no hoses, 10.6A. Clean filter with hoses, 10.3A. Filter clogged with sheetrock dust + hoses fitted, 7.9A.
    So I'll call 10.3A the normal running current. That works out to 1.66 electrical HP. Now, factoring in the best estimate of universal motor efficiency (55%), the motor puts out 0.91HP (mechanical).
    I didn't expect there to be such a drastic change in current draw between dirty and clean filter. This could be a good way to implement a "time to clean the filter" alarm.
    THE_RB and wayneh like this.
  13. strantor
    Oct 3, 2010
    4,302
    1,989
    oh yeah, and inrush current was 25.9A with filter off and hoses removed. So even using their ridiculous method of calculating "HP" would only put this thing at 4.17HP. They must have brought the winding temp down to -20C with liquid nitrogen like it was said in the link.
    PackratKing likes this.
  14. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    This would require some kind of low current over time, as any time it draws in anything large at one time will cause the current to drop drastically.
    Confirmed by the rpm rising considerably!;)
    Max.
    strantor likes this.
  15. wayneh
    Sep 9, 2010
    12,361
    3,220
    So they inflated the real number by ~6X. :eek:
    That's flagrant and far beyond mere stretching of the truth. I wonder if there have been any lawsuits on this yet. Seems like a class action would be a big enough potential payout to attract some hungry lawyers.
  16. wayneh
    Sep 9, 2010
    12,361
    3,220
    A ∆P monitor would probably be a better way to detect fouling. You could watch for peaks of ∆P - which I think will happen when the flow in the hose and nozzle is unrestricted. If the peaks reach a high enough sustained level, time to buy a new filter. (I clean mine with a hose.)
    This would help sell filters, so I'm surprised you don't see this "feature" already.
  17. t06afre
    May 11, 2009
    5,939
    1,222
  18. strantor
    Oct 3, 2010
    4,302
    1,989
  19. GopherT
    Nov 23, 2012
    6,296
    4,018
    Interesting that the average age was as high as it was. Then I realized the report was from 1980 - the pre Viagara period.
    Here is the monster referenced in two of the cases. No wand for their wand.
  20. t06afre
    May 11, 2009
    5,939
    1,222
    That is a 1930 model I think. This is how the dustette looked around 1980. I have been quite puzzled how they managed to end up in that awkward situation. But I think I understand more about how now:rolleyes:
