My Motorola says...
Discussion in 'Homework Help' started by viip, Oct 15, 2009.
  1. viip
    Apr 16, 2009
    23
    While listening to music on my Moto. i saw 44khz/128Kbps. Now I know one of it means sampling rate....But which one and what the other one represents?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  3. bumclouds
    May 18, 2008
    82
    On the x-axis, if the number of "slices" is high, you have a high sample rate.
    On the y-axis, if the number of "levels" (or possible discrete values) is high, you have a high bit-depth.
    To clarify the second one, if you were to lower the bit-depth, you would limit the number of discrete values the amplitude could be in your music, and you would hear "stepping". It's actually a common effect used in electronic music. I'm sure you've heard it before.. Listen: http://www.youtube.com/watch?v=BbsrIebJ2Bw
    Increase either and you're increasing the bit-rate of the music. i.e, number of bits per second.
