My Ideal microcontroller... any ideas?
Discussion in 'Embedded Systems and Microcontrollers' started by RMoreJr, Apr 26, 2013.
  1. RMoreJr
    Apr 26, 2013
    I wouild like to find a microcontroller that will handle the following on a single chip (or with minimum support chips)
    * Analog inputs - multi-channel
    * USB slave or master hardware
    * Programmable gain amplifier built in.
    * Realtime clock built-in
    * battery backed RAM (or suitable alternative)
    * Simple web server code for firmware updates and debugging using a web browser
    * Built-in buck or boost power converter circuit for converting available power to the voltage supply level of the processor (1.5V battery to 30V unregulated)
    and while we are at it... a bonus would be
    * Ethernet port built-in
    * rs232 level shifters built-in
    * rs485 port differential driver built-in
    Any Ideas?
  2. t06afre
    May 11, 2009
    5,939
    1,222
  3. tshuck
    Oct 18, 2012
    3,531
    675
    Cypress makes the PSoC(programmable system on a chip), which, I believe, does what you are wanting. They just released a $25 dev board for the PSoC4... making it hobby viable...
