look at this images for capacitor connection with max RS232 IC
yellow 5v dc
black ground
yellow 5v dc
black ground
That is not a chip I have used before. Please attach an image of the circuit you are trying to build. To do this, copy the link of the image, and then click the icon above (yellow square with mountain and sun), paste the link address (eg. http://www.abd.com/image123).Is this connection on breadboard is correct ?
ok I will be use 0.1 μf but can you tell me that my capacitor connection is correct or not , If this is correct then I want to add db9 male connector So I just want to confirmHello,
What are the values of the capacitors used?
For a 232 A you will need 0.1 μF for each one.
For a 232 you will need 1 μF for each one.
See this drawing from the datasheet:
Bertus
The diode is doing nothing; both ends are connected to the same electrical node.check out this images
black wire - ground
yellow wire - 9v d
What wayneh said.If your schematic is not ready, stop building now. It's pointless to build before you know where you are going.
look at thisif you want others to check it over before you supply power, post some good pictures.
look at post # 32 my cable is not working why its not workingThat is a much better diagram. What kind of help are you asking for?
by Jake Hertz
by Duane Benson
by Duane Benson
