My first HF Transmitter
Discussion in 'Wireless & RF Design' started by vu2nan, Jan 4, 2015.
  1. vu2nan
    Sep 11, 2014
    43
    10
  2. Ramussons
    May 3, 2013
    562
    92
    A couple of Decades old for this. Will you get the parts?
  3. Ramussons
    May 3, 2013
    562
    92
    Just remembering the old days. It's a challenge to play around with tubes. Power transformer and Variable Ganged caps may have to be cannibalised. Tubes ..... ?
    All the best.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    it would be nice if someone made a real modulation transformer these days for am transmitters, that choke modulator probably works pretty good, but at that power level wouldnt a centertapped pushpull transformer worked as good?
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    a center tapped transformer works for modulaion as a single ended audio output stage and a plate modulated stage. one tube for audio, one for rf, each connected to oposite ends of plate winding. power applied to center tap. a cheaper way used in some early cb's.
  6. harry85
    Jan 21, 2015
    5
    Transformer is use for Voltage to convert from AC to DC.
  7. alfacliff
    Dec 13, 2013
    2,449
    428
    no, rectifyer is to convert ac to dc. transformer is to step up or down voltage, isolate supply from load, match impedances, and other things, usually with ac on both sides.
