Thank you very much for the advice. it was very helpful.we are assured by the humm that the device is working.how efficient?? we don't know.First of all I am not expert in this topic The humming sound may tell you if the circuit works. But it will not tell you about how successful the ongoing process is. If the process works you will se see a slowly increase in the battery EMF. This because at least in theory. The battery desulfator process removes the sulfate coating the builds up on the lead plates in lead-acid batteries, and increase the battery internal resistance
Hope it work out for you. How did you made your circuit board. Did you use etching?Thank you very much for the advice. it was very helpful.we are assured by the humm that the device is working.how efficient?? we don't know.
Yeah hope for the best. We made a printed circuit board for the circuit by etching.Hope it work out for you. How did you made your circuit board. Did you use etching?
We have attached the bottom picture of PCB (though crude) but i think it meets the requirement.Progress! That is good.
What voltage do you measure across C1?
What toroids did you use for L1 and L2 (manufacturer and part number) and how many turns did you wind on each? (What counts is how many passes did the wire make through the center of the toroid; winding evenly is important).
I see that you did not use tape on the toroids before winding them. This can lead to rapid saturation of the toroidal core, which will result in high current in Q1 (the MOSFET).
Have you seen Ronald Dekker's page?
http://www.dos4ever.com/flyback/flyback.html
It's a really good resource for people wanting to experiment with inductors and switch-mode power supplies; the desulphator is actually very similar to a portion of a boost-type power supply.
Looks like you used aluminum electrolytic caps for both C1 and C4. They have higher ESR (equivalent series resistance) than other types. You will likely get better performance (and cooler caps) if you put several caps in parallel with C4. The exact capacitance is not terribly important; anything from 0.1uF to 100uF will help keep things cool.
Is C4 rated for at least 25v? (even that is marginal for a fully charged battery)
Standard BJT 555 timers can only get within about 1.3v of Vcc. That should be sufficient to turn off the MOSFET. However, if the voltage across C1 is lower than about 11v, the MOSFET may not be getting fully turned ON, which would lead to heating.
You can connect a trickle charger across C4. This will help a good deal to desulphate the battery more quickly.
No complaints; I have made boards much more ugly than that which worked.We have attached the bottom picture of PCB (though crude) but i think it meets the requirement.
What will help more is to have multiple small caps in parallel. For a given cap design, the larger it is (uF), the higher the ESR will be. Using multiple smaller caps will help to lower the ESR, and spread the heat around.We are using C4 100uF and 35V rating. We intend replacing it with 470uF 50V Caps.
OK.The battery voltage is 12.6V.
Voltages measured across c1 = 10.63v and across c4 = 12.55v
We shall tape the toroids before re-winding them.
The Three joints you circled have been cleaned of flux after reflowing. We have added another 100uF 35v capacitor in parallel with c4. The problem persists.(Mosfet and c4 get hot).Actually, I circled three joints to reflow, and two leads to clip/trim.
It really isn't so ugly or bad. It's just hard to solder due to the large amount of copper around those areas.
The photography isn't bad, either - better than many other such images that have been posted. It's really hard to take a good image of the reverse side of a board; you really have to use bounce/diffused flash, or better yet take the photo outdoors on an overcast day.
After having checked every thing we reached the conclusin probably our PWM needs adjustment. We, therefore replaced the R2 (68kohm) with a potentiometer (0~100kohm). We tried many settings finally at 30kohm result seems to be satisfactory.OK.
Your C4 may be defective; excessive leakage current. This is difficult to test unless you have a variable output DC voltage supply that is capable of putting out at most 35V.
The PWM time from the 555 might be incorrect. However, if your values are close to what's shown, they should be OK.
What is more likely is that the inductors are saturating due to the unknown toroid material and the way they were wound; no tape. If you look at Ronald Dekker's "Flyback Converters for Dummies" page, you will see what happens to current through an inductor when the saturation point is reached; a sharp increase in current.
Thread starter | Similar threads | Forum | Replies | Date |
P | lead acid desulphator | General Electronics Chat | 7 | |
B | Circuit modification for lead battery desulphator | Power Electronics | 57 | |
T | Strange Boost? Converter in Desulphator | General Electronics Chat | 4 | |
Desulphator and SLA Battery Trial | Power Electronics | 9 | ||
B | Desulphator design | General Electronics Chat | 1 |
by Aaron Carman
by Duane Benson
by Duane Benson
