my desulphator does not work why??????
Discussion in 'General Electronics Chat' started by De-Shulphator Crackers, Jan 11, 2010.
can a desulphator really do the claimed task?
Poll closed Jan 13, 2010.
  1. yes
    25.0%
  2. no
    75.0%
Multiple votes are allowed.
  1. De-Shulphator Crackers
    Jan 11, 2010
    21
    I was doing a research on desulphators and i came across many of the circuits claimed to give the high voltage and high current pulse at the terminals of the battery
    i pick a design from the frontiersprings.com, made the circuit and tested it but unfortunately the circuit did not increase the voltage at all.
    i have faced the following problems during my experiment.
    1. MOSFET gets hot (although the duty cycle from the 555 timer was correct.)
    2. There was no change in the voltage or current it is same as 12v as before.
    3. i also simulated the circuit on the proteus(simulator) but results are nil...
    attached here is the circuit diagram
    if anyone can help or guide kindly do??
  2. t06afre
    May 11, 2009
    5,939
    1,222
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    In the Frontier Springs version, the MOSFET has the drain and source connections reversed. It won't work like that.
    C1 and C4 should be rated for 25V or more. 16V is not adequate.
    [eta]
    C1 should really be 220uF.
    I edited a copy of the schematic. See the attached.
  4. De-Shulphator Crackers
    Jan 11, 2010
    21
    μ
    Thank you for your prompt reply. I had already corrected the drain and source connections on the MOSFET. my C1 is 47 μF 50 V, C4 is 100 μF 35 V. They do not seem to work .I will replace C1 with 220μF .I hope it works.
  5. De-Shulphator Crackers
    Jan 11, 2010
    21
    Yeah i have read the article you have refered
    and Yes it is making the humming noise but there is no change in the voltage and electrolyte is in its previous state no change.
  6. t06afre
    May 11, 2009
    5,939
    1,222
    This take about a 4 weeks to complete ;) But it may be that your battery is beyond the point of saving.
  7. De-Shulphator Crackers
    Jan 11, 2010
    21
    Is there any other indication other than humming noise to check the working of de sulphator???
  8. De-Shulphator Crackers
    Jan 11, 2010
    21
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Do you have an oscilloscope aka O-scope? It's kind of difficult to diagnose these things without that kind of equipment, as they put out bursts of voltage at various frequencies.
    It's dry weather even in Florida, which is unusual. When humidity is really low, ESD (electrostatic discharge) is a big problem when dealing with FETs. One little "zap" and they are toast.
  10. De-Shulphator Crackers
    Jan 11, 2010
    21
    humidity over here is 87% in the evening so its not the problem
    but i donot have the oscilloscope
  11. t06afre
    May 11, 2009
    5,939
    1,222
    First of all I am not expert in this topic ;) The humming sound may tell you if the circuit works. But it will not tell you about how successful the ongoing process is. If the process works you will se see a slowly increase in the battery EMF. This because at least in theory. The battery desulfator process removes the sulfate coating the builds up on the lead plates in lead-acid batteries, and increase the battery internal resistance
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What did you use for the inductors?
    They need to be pretty heavy-duty, capable of at least a couple of Amperes of current.
    You may have burned one of them up when the MOSFET was installed backwards. It's body diode would have caused maximum current flow through both of the inductors until the MOSFET diode or one of the coils burned up.
  13. De-Shulphator Crackers
    Jan 11, 2010
    21
    I used small inductors one of which burned out in less than a minute.now I l have wound L1 inductor with a 21 guage wire on a iron powder toriod core.L2 has been wound on a ferrite core with 21 guage wire.That would provide enough current rating .
  14. De-Shulphator Crackers
    Jan 11, 2010
    21
    Would it be better if we replace 220uf capacitor by 1000uf???
  15. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    220uF should be fine.
    However, how are you testing the circuit? Are you connecting it to a battery that is at least 11v?
    If your wiring to the circuit is of small diameter, it may be causing much of the pulse to be retained on the board. That could destroy the diode or MOSFET.
    Having some pictures of your project would help quite a bit. Can you post some?
    Or, at least the board layout that you used?
  16. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Oh, for those who don't think these things work...
    It took a month, but I successfully desulphated a lawnmower battery. Three cells were so heavily sulphated that it wouldn't start the mower, and the electrolyte specific gravity in those cells was nearly 1 (plain water) After a month of treatment, the battery was completely recovered; all cells were back up to 1.255-1.260 in specific gravity.
  17. De-Shulphator Crackers
    Jan 11, 2010
    21
    we have connected the circuit to battery which is 12.2v.we measured the output voltage with a voltmeter on the battery terminals,which remains unchanged.
    we have not uploaded the pictures because we have assembled it on a bread(testing) board.
    you may be right about the light wires. we will replace them with heavy wires. that may solve our problem.
  18. De-Shulphator Crackers
    Jan 11, 2010
    21
  19. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK, you can't breadboard this circuit, or test it with a typical lab supply.
    You'll need to build it on a PCB, or at least perfboard/stripboard, and connect it to a battery using short wires of stranded AWG16 or larger; the larger the better. The power traces on the PCB should be pretty wide.
    The longer and smaller gauge the wiring is, the less effective it'll be, as the inductance of the wiring will reduce the peak voltage spikes - which is what you want to deliver to the battery.
  20. De-Shulphator Crackers
    Jan 11, 2010
    21
    Thank you very much for the guidence we will implement it on PCB , test it and than get back to you for further guidence.
