My board killed three IR2110 ICs...... Help Plz
Discussion in 'The Projects Forum' started by onlyvinod56, Jul 1, 2016.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    Hello All....
    I was trying to design a H-Bridge inverter and started with one leg driver IR2110. Based on the datasheet and some blogs, I build the circuit and tested.
    See the attachment. First i got the low side pulses across the lower mosfet (gate and source). No pulses on high side. After some trials, periodically Vcc and common are getting short circuited. I tried with three ICs and all got fried. Any suggestions.??
    Attachment 1: IMG_20160701_154306.jpg Left side supply (VCC and COM) is showing overload
    Attachment 2: IMG_20160701_154350.jpg IR2110 board with ARDUINO as controller (pulse period is 10ms)
    Attachment 3: IMG_20160701_154412.jpg Tried with another board.... same results
    Attachment 4: IMG_20160701_154435.jpg Total three boards with three ICs failed
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Can you post your schematic? Is your "load" a dead short?
    John
  3. Alec_t
    Sep 17, 2013
    5,977
    1,136
  4. onlyvinod56
    Oct 14, 2008
    362
    I did not connect any load. I just connected two LEDs (LED + limiting resistor) across each MOSFET's gate and source.
    One more thing, in place of UF4007, I used MUR1100 diodes.
  5. onlyvinod56
    Oct 14, 2008
    362
    ThankQ... I will check it out
  6. Lestraveled
    May 19, 2014
    1,957
    1,218
    I absolutely agree with @Alec_t . The Fairchild AN-6076 is an excellent description of what is happening. Look at Figure 18 in the app note.
    Here is an example
