my arduino doesn't work
Discussion in 'Embedded Systems and Microcontrollers' started by regal006, Sep 6, 2012.
  1. regal006
    Jul 14, 2012
    20
    i don't have an account in arduino forums, so i'll try my luck here
    i'm a starter . i always get this error
    avrdude: stk500_getsync(): not in sync: resp=0x00
    i made this thing worked before
    does tHAT mean my arduino is broken?
    i tried to do what other forum's solution to this problem
    i got an arduino diecimila168
    i used the right port.
    i have the driver working correctly
    thanks in advance
  2. W4GNS
    Member
    Dec 1, 2008
    17
  3. justtrying
    Mar 9, 2011
    329
    405
    double check that you have the right board and the right port selected (check port in devices manager) once again and if it still does not work, reset the board. I've had same problem several times, and resetting the controller solved it every time.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Also check to make sure that the correct board has been selected by clicking on the TOOLS menu and clicking on BOARD from the drop-down menu. You will be presented with the list of all the boards available. Choose yours from the llist.
    Don't rule out the possibility that your USB cable failed.
    If you have not already done so, I would recommend you download the latest Arduino IDE version 1.0.1.
    hgmjr
