With the TL431 electret booster as published in Elektor a few years ago, I included the current draw of the electret capsule in the overall setup. Initially I included a 47k pot as the bottom resistor in the DC nfb path so the output operating point could be set just so.That's the TS want to reducing the parts, so if he care about the quality then he should keep that, sometimes the numbers of parts and quality of sound that you can't have both, when you change any components of TL431 then it could be affecting the output voltage, that's why I don't want to change the components of TL431, only adding some parts through the capacitor, so you can see the easy way I suggested.
With DC coupling between the capsule and TL431 - its as good as it gets. Any DC blocking/coupling capacitor will have a tradeoff between size/cost and low frequency roll off. Most audiophools claim that coupling capacitors taint the audio to a greater or lesser degree depending on dielectric type.
