Hi everyone! Im using the 74HC595N IC chip. What is happening is that My "Binary counter project" Is not performing correctly. Basically, Pin 4 on the IC is acting as Q0, pin 3 as Q1, pin 2 as Q2 pin 1 as Q3 and pin 15 as Q4. The 74HC595N data sheet said that the bits would be shifted in order but my first four LEDs, representing each bit do not work. It seems like the output pins are of the wrong order, however I cant get the three LED pins to work when i change the output Pins on the chip. I also have an identical chip and that is doing the same thing.
Im happy to take a picture to show all the wiring, and also a video if that would help. I will take a picture of it in a moment, just going to neaten up the wires Thanks for reading and hopefully someone could help me on this issue!
