No others what about IC 1 pin 2 to 6 and the current connection to pin 7 ? I could cut the trace easily enough but will need a jumper from 2-6John said:Are there jumpers we haven't discussed? ?
I am assuming this is the R4 1K resistor ? It is flush mounted so it will be on the back.and a diode soldered across a resistor. You can just solder it to the leads of the resistor.
Yes I do realize the PWM delivers 12V in Pulses , I should have said 50% instead of 6VAs for the 6V or 12V question, remember with PWM at low frequency and with a small motor, the motor will be seeing 12V,
