My 16F876A pic doesn't work ?
Discussion in 'Embedded Systems and Microcontrollers' started by Chaabane, Feb 19, 2010.
  1. Chaabane
    Nov 30, 2009
    37
    i'm trying to put acode in pic16F876A,but i can't
    first i'm using winpic to send the code and a simple programmer wiht rs232 connection
    i can program 16F84A pic
    i tested the device with winpic tools and it says "Device OK",it even know wich device is connection
    i can read all,erase all, the memory.everything is okey
    but when i'm trying to use program all,it stops at 10% or so,and gives me an error "can't write 0x0000", something like that.
    i used another code,but always the same error.
    i programmed this pic before. But now,i can't
    it seems broken
    how can i make sure its broken
    coz this stuff in Algeria, are little bit expensive (aboout 7 euro)
    Any help
  2. BMorse
    Sep 26, 2009
    2,675
    234
    the last time you programmed it, you did not set any of the fuses for code protect or something, did you? Can you erase it and do a blank check? Do you have the Low Voltage programming enabled? If you do, do you have RB3 tied to Vdd?
